* | arm/gp32: Remove | Aun-Ali Zaidi | 2015-12-13 | 1 | -25/+0 |
| | | | | updates #2451. | ||||
* | General - Remove extraneous blank line in license message | Joel Sherrill | 2012-05-03 | 1 | -1/+0 |
| | | | | | | | | | | | | | Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly. | ||||
* | 2007-03-12 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-03-12 | 1 | -1/+1 |
| | | | | | | | * console/uart.c, start/start.S, startup/linkcmds, startup/memmap.c: Correct license URL and/or fix mistake in copyright notice. Both of these mistakes appear to be from code submitted after these changes were made previously. | ||||
* | 2005-03-11 Philippe Simons <loki_666@fastmail.fm> | Jay Monkman | 2005-03-11 | 1 | -0/+28 |
* acinclude.m4: Added gp32 BSP. * gp32/.cvsignore, gp32/Makefile.am, gp32/README, gp32/bsp_specs, gp32/configure.ac, gp32/console/.cvsignore, gp32/console/conio.c, gp32/console/console.c, gp32/console/defaultfont.c, gp32/include/.cvsignore, gp32/include/bsp.h, gp32/include/conio.h, gp32/include/tm27.h, gp32/start/.cvsignore, gp32/start/start.S, gp32/startup/.cvsignore, gp32/startup/bspstart.c, gp32/startup/exit.c, gp32/startup/linkcmds, gp32/startup/memmap.c: New files. |
