* | bsp/gdbarmsim: Switch to the standard arm/shared/startup. | Chris Johns | 2014-05-26 | 1 | -401/+0 |
| | | | | | | | Switch to the standard ARM startup code. This requires adding the standard interrupt code. The interrupt code does nothing at this point in time. I do not know if the ARM simulator in GDB supports interrupts. | ||||
* | bsp/gdbarmsim: Do not call bsp_cleanup() | Sebastian Huber | 2012-12-07 | 1 | -2/+0 |
* | 2010-12-03 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-12-03 | 1 | -2/+3 |
| | | | | | * bsp_specs, start/start.S, startup/linkcmds: Use linker command base file. | ||||
* | 2010-04-07 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-07 | 1 | -0/+1 |
| | | | | * start/start.S: Verify boot_card() is passed a NULL. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-29 | 1 | -28/+28 |
* | 2009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-01 | 1 | -0/+403 |
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, preinstall.am, console/.cvsignore, console/console-io.c, include/.cvsignore, include/bsp.h, include/irq.h, include/swi.h, start/.cvsignore, start/start.S, startup/.cvsignore, startup/bspreset.c, startup/bspstart.c, startup/linkcmds, startup/syscalls.c: New files. |
