path: root/c/src/lib/libbsp/arm/gba/start (follow)
* arm/gba: RemoveAun-Ali Zaidi2015-12-122-421/+0
| | | | updates #2449.
* arm: Rename arm_exc_interrupt()Sebastian Huber2013-01-071-1/+1
| | | | Rename arm_exc_interrupt() to _ARMV4_Exception_interrupt().
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-112-4/+0
* General - Remove extraneous blank line in license messageJoel Sherrill2012-05-031-1/+0
| | | | | | | | | | | | | Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly.
* 2010-04-30 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-04-301-1/+1
| | | | | | | | | | | | | | * irq/irq_asm.S, irq/irq_init.c, irq/bsp_irq_asm.S, irq/bsp_irq_init.c: Removed files. * Makefile.am, preinstall.am: Reflect changes above. Added generic interrupt support modules. * irq/irq.h, irq/irq.c: The previous interrupt warning fix changed the interrupt handler API. To fix this problem the generic interrupt support framework will be used now. This eliminates a lot of copy and paste code. The interrupt header file is now <bsp/irq.h>. * include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION. * start/start.S, startup/bspstart.c, clock/clockdrv.c, console/console.c, timer/timer.c: Interrupt support changes.
* 2010-04-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-04-071-11/+7
| | | | * start/start.S: Verify boot_card() is passed a NULL.
* Whitespace removal.Ralf Corsepius2009-11-291-1/+1
* 2009-04-28 Chris Johns <chrisj@rtems.org>Chris Johns2009-04-281-0/+5
| | | | * start/start.S: Update for boot_card command line change.
* 2005-07-06 Markku Puro <markku.puro@kopteri.net>Joel Sherrill2005-07-062-0/+425
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, clock/clockdrv.c, console/conio.c, console/console.c, console/defaultfont.c, include/arm_mode_bits.h, include/asm_macros.h, include/bsp.h, include/bspopts.h.in, include/conio.h, include/gba.h, include/gba_registers.h, include/tm27.h, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c, start/logo.S, start/start.S, startup/bspstart.c, startup/cpu.c, startup/cpu_asm.S, startup/exit.c, startup/linkcmds, timer/timer.c: New files.
