updates #2449.
These files were left after running the script in the previous patch.
Add doxygen to the header files in the arm/gba include,
irq, and console directories.
Conflicts:
* include/bsp.h, startup/bspreset.c:
* gba/clock/clockdrv.c, gba/console/conio.c, gba/console/console.c,
gba/console/defaultfont.h, gba/include/arm_mode_bits.h,
gba/include/asm_macros.h, gba/include/bsp.h, gba/include/conio.h,
gba/include/gba.h, gba/include/gba_registers.h, gba/irq/irq.c,
gba/irq/irq.h, gba/startup/bspstart.c, gba/timer/timer.c,
gp32/include/bsp.h, gp32/startup/bspreset.c, gp32/startup/bspstart.c,
nds/tools/runtest, shared/comm/uart.c, shared/comm/uart.h,
smdk2410/include/bsp.h: Fix typo where license said
found in found in.
* irq/irq_asm.S, irq/irq_init.c, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c: Removed files.
* Makefile.am, preinstall.am: Reflect changes above. Added generic
interrupt support modules.
* irq/irq.h, irq/irq.c: The previous interrupt warning fix changed the
interrupt handler API. To fix this problem the generic interrupt
support framework will be used now. This eliminates a lot of copy and
paste code. The interrupt header file is now <bsp/irq.h>.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* start/start.S, startup/bspstart.c, clock/clockdrv.c,
console/console.c, timer/timer.c: Interrupt support changes.
* console/conio.c, console/console.c, include/conio.h:
Let *getch return "int". Remove casts.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* clock/clockdrv.c, include/bsp.h, startup/bspstart.c: Eliminate copies
of the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* include/arm_mode_bits.h: Convert C++ style comments to C style.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
clock/clockdrv.c, console/conio.c, console/console.c,
console/defaultfont.c, include/arm_mode_bits.h, include/asm_macros.h,
include/bsp.h, include/bspopts.h.in, include/conio.h, include/gba.h,
include/gba_registers.h, include/tm27.h, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_init.c, start/logo.S, start/start.S, startup/bspstart.c,
startup/cpu.c, startup/cpu_asm.S, startup/exit.c, startup/linkcmds,
timer/timer.c: New files.
