* | bsps: Move interrupt controller support to bsps | Sebastian Huber | 2018-04-23 | 1 | -323/+0 |
| | | | | | | This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | bsp/edb7312: Use public include path | Chris Johns | 2018-01-04 | 1 | -1/+1 |
| | | | | Update #3254. | ||||
* | arm/edb7312: Fix warnings | Joel Sherrill | 2014-10-20 | 1 | -1/+5 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | General - Remove extraneous blank line in license message | Joel Sherrill | 2012-05-03 | 1 | -1/+0 |
| | | | | | | | | | | | | | Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly. | ||||
* | 2010-04-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-04-30 | 1 | -31/+25 |
| | | | | | | | | | * irq/bsp_irq_init.c: Removed file. * Makefile.am, preinstall.am: Reflect change above. Added generic interrupt support modules. * include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION. * startup/bspstart.c, irq/bsp_irq_asm.S, clock/clockdrv.c, network/network.c: Interrupt support changes. | ||||
* | ARM bsp maintenance | Thomas Doerfler | 2009-07-17 | 1 | -2/+2 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 1 | -5/+5 |
| | | | | | | | * clock/clockdrv.c, console/uart.c, include/bsp.h, include/ep7312.h, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, start/start.S, startup/bspstart.c, startup/exit.c, startup/linkcmds, timer/timer.c: URL for license changed. | ||||
* | 2002-11-13 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 2002-11-13 | 1 | -0/+329 |
* New BSP. * .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, README, times, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/uart.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/ep7312.h, irq/.cvsignore, irq/Makefile.am, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, network/Makefile.am, network/network.c, start/.cvsignore, start/Makefile.am, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/exit.c, startup/linkcmds, timer/.cvsignore, timer/Makefile.am, timer/timer.c, wrapup/.cvsignore, wrapup/Makefile.am: New file. |
