Close #3250.
Close #4081.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3387.
upgrade to that version.
Close #3387.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Updates #3250.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: undefine BSP_PRESS_KEY_FOR_RESET
* startup/bspreset.c, include/ep7312.h: Support skyeye shutdown device
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac, clock/clockdrv.c, startup/bspreset.c: Adjust clock
initialization for clock tick so rtmonuse test now runs on Skyeye.
Joel added configure magic and place holder in bspreset.c for Skyeye
hardware reset device support.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am, configure.ac, console/uart.c: Use standardized
bsp_cleanup() which can optionally print a message, poll for user to
press key, and call bsp_reset(). Using this eliminates the various
bsp_cleanup() implementations which had their own implementation and
variety of string constants.
* startup/bspclean.c: Removed.
* Makefile.am, configure.ac, startup/bspstart.c: Split out
bsp_get_work_area() into its own file and user BSP Framework to
perform more initialization.
* startup/bspgetworkarea.c: New file.
network/Makefile.am, irq/Makefile.am, start/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake
compilation rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
irq/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am: Remove.
Reflect changes to bsp.am.
* configure.ac, network/Makefile.am: Don't build if networking disabled.
* startup/linkcmds: Add sections to remove warnings.
* New BSP.
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, README,
times, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c,
console/.cvsignore, console/Makefile.am, console/uart.c,
include/ep7312.h, irq/.cvsignore, irq/Makefile.am, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, network/Makefile.am,
network/network.c, start/.cvsignore, start/Makefile.am,
start/start.S, startup/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
timer/.cvsignore, timer/Makefile.am, timer/timer.c,
wrapup/.cvsignore, wrapup/Makefile.am: New file.
