Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
This section can be use to provide a cache coherent memory area via
rtems_cache_coherent_add_area().
Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
* startup/umonsupp.c: Include <rtems/umon.h> (Missing prototype).
* bsp_specs, start/start.S, startup/linkcmds.csb337,
startup/linkcmds.csb637: Use linker command base file.
* Makefile.am, preinstall.am: Added generic interrupt support modules.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* startup/bspstart.c, network/network.c: Interrupt support changes.
* README, README.kit637_v6, console/sed1356_16bit.h, startup/memmap.c:
Missing parts of previous commit.
* Makefile.am, preinstall.am, console/fbcons.c, console/font8x16.h,
console/sed1356.c, console/uarts.c, include/sed1356.h,
startup/bspstart.c, startup/linkcmds.csb337, startup/linkcmds.csb637,
startup/memmap.c, startup/umonsupp.c: Update to match development
version.
* configure.ac: Add RTEMS_BSP_LINKCMDS.
* make/custom/csb637.cfg: Remove LDFLAGS. Remove RTEMS_LINKCMDS.
* startup/linkcmds: Remove (Rename into linkcmds.csb337).
* startup/linkcmds.csb337: New (Renamed from linkcmds).
* Makefile.am: Rework linkcmds handling.
* startup/linkcmds, startup/linkcmds.csb637: Move .init section from
the front of the executable so the start label has the first
instruction in the executable.
* Makefile.am, preinstall.am: Add MicroMonitor support.
* startup/umonsupp.c: New file.
* startup/bspstart.c: Eliminate unused variables.
* Makefile.am, configure.ac, preinstall.am, console/uarts.c,
include/bsp.h, startup/memmap.c: Add support for /dev/fbcons which is
a console type output only device to print to the LCD screen. The
video controller (SED) and fonts are copied from MicroMonitor and
proper attribution is made in those files and confirmed by Ed Sutter.
* console/fbcons.c, console/font8x16.h, console/sed1356.c,
console/sed1356_16bit.h, include/sed1356.h: New files.
* Makefile.am, README, configure.ac, preinstall.am, start/start.S,
startup/memmap.c: Add csb637 as alias and variant.
* startup/linkcmds.csb637: New file.
* Makefile.am, configure.ac, startup/bspstart.c: Use standardized
bsp_cleanup() which can optionally print a message, poll for user to
press key, and call bsp_reset(). Using this eliminates the various
bsp_cleanup() implementations which had their own implementation and
variety of string constants.
* startup/bspreset.c: New file.
* startup/bspclean.c: Removed.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspstart.c: Remove unnecessary includes of
rtems/libcsupport.h and rtems/libio.h.
* Makefile.am, configure.ac, startup/bspclean.c, startup/bspstart.c:
Now support bsp_get_work_area() and used shared implementation of it
and bsp_pretasking_hook.
* Makefile.am: No BSP should use exit.c as a file name. exit() is POSIX
routine.
* startup/bspclean.c: New file.
* startup/exit.c: Removed.
* startup/bspstart.c: Add missing prototypes.
* csb336/startup/bspstart.c, csb337/startup/bspstart.c,
edb7312/startup/bspstart.c, gba/startup/bspstart.c,
gp32/startup/bspstart.c, rtl22xx/startup/bspstart.c: Add capability
for bootcard.c BSP Initialization Framework to ask the BSP where it
has memory for the RTEMS Workspace and C Program Heap. These
collectively are referred to as work area. If the BSP supports this,
then it does not have to include code to split the available memory
between the two areas. This reduces the amount of code in the BSP
specific bspstart.c file. Additionally, the shared framework can
initialize the C Library, call rtems_debug_enable(), and dirty the
work area memory. Until most/all BSPs support this new capability, if
the BSP supports this, it should call
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac. When
the transition is complete, this autoconf macro can be removed.
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* Makefile.am, startup/bspstart.c: Moved most of the remaining CPU
Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
PR 1257/bsps
* csb336/network/lan91c11x.c, csb337/startup/bspstart.c,
edb7312/irq/irq.c, gba/irq/irq.c, gba/irq/irq_init.c,
gp32/startup/bspstart.c, rtl22xx/startup/bspstart.c,
shared/abort/abort.c, shared/abort/simple_abort.c,
shared/irq/irq_init.c: Code outside of cpukit should use the public
API for rtems_interrupt_disable/rtems_interrupt_enable. By bypassing
the public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
* startup/bspstart.c: Eliminate maximum_drivers configuration parameter
since it was used to configure a no longer used feature. Device names
are now part of the filesystem not in a table.
* console/uarts.c, include/bsp.h, start/start.S, startup/bspstart.c,
startup/exit.c, startup/linkcmds: Correct license URL and/or fix
mistake in copyright notice. Both of these mistakes appear to be from
code submitted after these changes were made previously.
* startup/bspstart.c: Remove assignments of
Cpu_table.do_zero_of_workspace to TRUE since TRUE is the default
value in boot_card.c
PR 751/bsps
* startup/linkcmds: Cleanup.
* network/network.c: Added hardware initialization
code.
