Close #3250.
Close #4081.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3387.
upgrade to that version.
Close #3387.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Updates #3250.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
* Makefile.am, configure.ac, console/uarts.c: Add initial support for
Kit637 version of CSB637.
* README.kit637_v6, make/custom/kit637_v6.cfg: New files.
* configure.ac: Add RTEMS_BSP_LINKCMDS.
* make/custom/csb637.cfg: Remove LDFLAGS. Remove RTEMS_LINKCMDS.
* startup/linkcmds: Remove (Rename into linkcmds.csb337).
* startup/linkcmds.csb337: New (Renamed from linkcmds).
* Makefile.am: Rework linkcmds handling.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* Makefile.am, configure.ac, console/uarts.c: Add console device that
uses MicroMonitor to do actual input and output. This driver should
work on any board that uses MicroMonitor.
* Makefile.am, configure.ac, preinstall.am, console/uarts.c,
include/bsp.h, startup/memmap.c: Add support for /dev/fbcons which is
a console type output only device to print to the LCD screen. The
video controller (SED) and fonts are copied from MicroMonitor and
proper attribution is made in those files and confirmed by Ed Sutter.
* console/fbcons.c, console/font8x16.h, console/sed1356.c,
console/sed1356_16bit.h, include/sed1356.h: New files.
* Makefile.am, README, configure.ac, preinstall.am, start/start.S,
startup/memmap.c: Add csb637 as alias and variant.
* startup/linkcmds.csb637: New file.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am, configure.ac, startup/bspstart.c: Use standardized
bsp_cleanup() which can optionally print a message, poll for user to
press key, and call bsp_reset(). Using this eliminates the various
bsp_cleanup() implementations which had their own implementation and
variety of string constants.
* startup/bspreset.c: New file.
* startup/bspclean.c: Removed.
* Makefile.am, configure.ac, startup/bspclean.c, startup/bspstart.c:
Now support bsp_get_work_area() and used shared implementation of it
and bsp_pretasking_hook.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
times, console/uarts.c, include/.cvsignore, include/bsp.h,
include/tm27.h, network/.cvsignore, network/network.c,
start/.cvsignore, start/start.S, startup/.cvsignore,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
startup/memmap.c: New files.
