Close #3250.
Close #4081.
Update #4267.
This BSP family uses only one linker command file. Use the standard
name.
Update #3818.
- Port the jbang code from C++ to C to enable DBGEN.
- Hook the libdebugger ARM backend support to return the base address
of the debug register set.
Close #3667.
Use the standard ARMv7-M systick module for the ARMv7-M CPU counter
instead of DWT counter since the DWT counter is affected by power saving
states.
Use an inline function for _CPU_Counter_difference() for all ARM BSPs.
Update #3456.
Add rtems_counter_frequency() API function. Use it to initialize the
counter value converter via the new system initialization step
(RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation
and the counter converter. It avoids an unnecessary pull in of the
64-bit integer division from libgcc.
Update #3456.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
This was used by the not supported "make dist".
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
Update #3254.
header file.
Update #3254.
maintain.
Update #3254.
Update #3239.
Update ticket #2891 and my GSOC project
add c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
modify c/src/lib/libbsp/arm/beagle/include/i2c.h
modify c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
modify c/src/lib/libcpu/arm/shared/include/am335x.h
modify c/src/lib/libbsp/arm/beagle/Makefile.am
Now can read the EEPROM by i2c, the test application link is: https://github.com/hahchenchen/GSOC-test-application
delete c/src/lib/libbsp/arm/beagle/misc/i2c.c
