* arm_bare_bsp/.cvsignore, arm_bare_bsp/ChangeLog,
arm_bare_bsp/Makefile.am, arm_bare_bsp/bsp_specs,
arm_bare_bsp/configure.ac, arm_bare_bsp/clock/clockdrv.c,
arm_bare_bsp/include/.cvsignore, arm_bare_bsp/include/bsp.h,
arm_bare_bsp/include/registers.h, arm_bare_bsp/include/tm27.h,
arm_bare_bsp/irq/bsp_irq_asm.S, arm_bare_bsp/irq/bsp_irq_init.c,
arm_bare_bsp/irq/irq.c, arm_bare_bsp/irq/irq.h,
arm_bare_bsp/start/start.S, arm_bare_bsp/startup/bspstart.c,
arm_bare_bsp/startup/exit.c, arm_bare_bsp/startup/linkcmds: Removed.
* startup/linkcmds: Add .gnu.linkonce.b section.
* startup/bspstart.c: Convert to using c99 fixed size types.
* startup/linkcmds: Add more memory and sections so tests can link.
This is a generic BSP for a CPU model so OK to do this.
irq/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, irq/Makefile.am,
wrapup/Makefile.am: Remove.
* irq/Makefile.am: Ditto.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* startup/linkcmds: Remove SEARCH_DIR.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* console/Makefile.am: Misc cleanups and fixes.
* irq/Makefile.am: Misc cleanups and fixes.
* console/Makefile.am: Remove all: $(ARCH).
* irq/Makefile.am: Remove all: $(ARCH).
* startup/Makefile.am: Remove all: $(ARCH).
* wrapup/Makefile.am: Remove all: $(ARCH).
* irq/Makefile.am: Add preinstallation dirstamp support.
* include/bsp.h, include/registers.h, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, start/start.S,
startup/bspstart.c, startup/exit.c: URL for license changed.
irq/Makefile.am: Reflect having moved automake.
* startup/Makefile.am: Remove USE_INIT_FINI.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* startup/exit.c: Include rtems/bspIo.h instead of bspIo.h.
start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am:
Include compile.am.
That BSP now has a stub clock driver so the tests can link even
if they won't execute. A handful of Makefiles had to be updated
and we had to account for printk.c being a shared file now.
