* configure.in: Remove.
* include/Makefile.am: Use *_HEADERS instead of *H_FILES, add
bspopts.h.
* include/.cvsignore: Add bspopts.h.
* include/bsp.h: Add bspopts.h.
* console/Makefile.am: Use *_HEADERS instead of H_FILES.
* Shared memory support removed since it was non-functional.
* shmsupp/.cvsignore, shmsupp/Makefile.am, shmsupp/addrconv.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c: Removed.
* configure.in, Makefile.am, wrapup/Makefile.am: Modified to
reflect above.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that contains:
* Removes MKLIB
handling)
that converts the a29k directory to automake.
NOTE: This port is not based on the GNU tools so no one can test it.
