path: root/c/src/lib/include/zilog/Makefile.am (follow)
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-161-21/+0
| | | | | | | | | * include/zilog/Makefile.am: Remove. * include/motorola/Makefile.am: Remove. * include/sys/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/Makefile.am: Handle subdirs, require automake-1.5 * Makefile.am: Require automake-1.5.
* 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-281-1/+1
| | | | | | | | * include/zilog/Makefile.am: Use 'PREINSTALL_FILES ='. * include/motorola/Makefile.am: Use 'PREINSTALL_FILES ='. * include/sys/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-3/+3
| | | | | | | * include/zilog/Makefile.am, include/Makefile.am, include/motorola/Makefile.am, include/sys/Makefile.am include/rtems/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-6/+3
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-6/+6
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-041-3/+3
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-071-0/+24
Ralf Corsepius <corsepiu@faw.uni-ulm.de> which converted many Makefile.in's to Makefile.am's. This added a lot of files.
