Comments follow:
Building linux/posix fails due to including lib/include/sys/cdefs.h
instead of linux's sys/cdefs.h.
AFAIS, this sys/cdefs.h is specific to newlib and should probably
not be used on any unix host.
Therefore, I changed the relevant Makefile.am/configure.in to
condionally install sys/cdefs.h only if newlib is present.
This triggered another bug inside of the newlib-check for one of
RTEMS target's (Unfortunately I can't remember which - mips/i960 ?
... one of the more exotic ...), for which int func() isn't
identical to void func().
Note: This patch needs to be tested under Cygwin and Solaris. I am
particularily unsure about Cygwin/posix, as it applies a different
version newlib which must not trigger RTEMS newlib check (it is
supposed to fail) and if it may need RTEMS's sys/cdefs.h.
<corsepiu@faw.uni-ulm.de> to fix the following:
* lib/configure.in actually is libc's configure.in, so let it depend
on libc not on lib [In my Cygnus/GNU configuration scheme, lib/include
and lib/libc are treated as one unit, while libcpu and libbsp are
treated as separate units.]
* Allow empty --enable-bare* flags for the bare bsp. The formerly
used scheme is too strict for our multilib experiments.
that contains:
* Removes MKLIB
handling)
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
that fixes the following problems:
1. Removing bogus ';' in some configure.in (cosmetical fix)
2. Moves GAS_CODE16 checks to libbsp/i386/*/configure.in (essential fix)
#2 was responsible for the gcc/binutils-2.9.5 choking while building for
the pc386.
Addtional major bugs:
places under the libbsp tree.
rdir=/opt/rtems
cd $idir
find . -type f | while read file
do
if [ ! -f ${file} ] ; then
echo ${file} missing
fi
done
c/src/lib/libmisc to c/src/libmisc.
to its own top level package.
a top level more independently configured package.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
c/src/lib/librtems++ and c/src/lib/include/rtems++ to
their own package librtems++ at the top of the tree.
mkdir c/src/librtems++
cp c/src/lib/librtems++/README c/src/librtems++
mkdir c/src/librtems++/src
cp c/src/lib/librtems++/*.cc c/src/librtems++/src
cp c/src/lib/librtems++/Makefile.in c/src/librtems++/src
mkdir c/src/librtems++/include
mkdir c/src/librtems++/include/rtems++
cp c/src/lib/include/rtems++/*.h c/src/librtems++/include/rtems++
patch -p1 <rtems-rc-19990802-5.diff
rm -rf c/src/lib/librtems++
rm -rf c/src/lib/include/rtems++
Attention:
* The procedure above copies the files first, then patches them
and finally removes the old files afterwards. This has been done
to enable you to copy the files in CVS to preserve their history.
configuration and unix/posix:
c/src/lib/libc/Makefile.in
only (was completely broken).
Linux-posix.cfg.
of other bsp's/CPU.
cd <srcdir>
and
cd c/src/lib; autoconf
or
After upgrading my linux box to the brand new SuSE 6.2 release, which is
glibc-2.1 based, I came across a bug in RTEMS - IIRC, I even warned you
about it about 1/2 a year ago, but nothing has been done since then :-.
The *.m4 macros to check for SYSV/IPC are broken for linux/glibc2.1,
because they assume that linux always defines union semun, which isn't
true anymore for glibc2.1 (the manpage for semctl states _X_OPEN
specifies it this way). Therefore I have tried to implement a more
general approach for handling SYSV for unix/posix which checks for
presence of struct semun, instead of trying to evaluate OS specific
preprocessor symbols.
This approach is a bit adventureous, because I only tested it with
linux/glibc2.1 and linux/libc5, but not under other Unix variants RTEMS
supports. I am quite confident it will work on other hosts, too, but who
knows :-.
[FYI: I think this might also is the cause of some problems with RedHat
6.X / Mandrake linux recently reported on the rtems list -- rtems-4.0.0
can not be build for posix on any glibc2.1 based host]
Furthermore the patch below contains a couple of minor fixes and
configuration cleanups, which IMO should be applied before releasing a
new snapshot.
To apply this patch:
patch -p1 < rtems-rc-19990709-8.diff
problem with the HAS_MP patch and regenerated files.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
