based board.
outside RTEMS. Comment:
I found a couple of places other than RTEMS where I'd like to use
the declarations supplied in m68360.h. To make this easier to do,
I've redone the declarations in m68360.h to use standard C types.
getting the spurious trap handling to work required a couple more
fixes - I have attached a patch against rtems-4.0.0 with the
necessary changes. I also added functionality so that the
address of the trapped instruction is reported and in case of
a data access error, the data address is also reported.
> > I think I have found a bug in src/exec/scor/sparc/cpu/erc32.h in:
> > #define ERC32_Disable_interrupt( _source, _previous ) \
> > do { \
> > unsigned32 _level; \
> > unsigned32 _mask = 1 << (_source); \
> > sparc_disable_interrupts( _level ); \
> > (_previous) = ERC32_MEC.Interrupt_Mask; \
> > ERC32_MEC.Interrupt_Mask = _previous | _mask; \
> > sparc_enable_interrupts( _level ); \
> > (_previous) &= ~_mask; \ <- IS THIS CORRECT...?
> > } while (0)
> > The previous interrupt mask is returned after first clearing the
> > bit to be disabled, regardless whether the bit was set before or
> > not. If the bit was set (interrupt masked), subsequent call to
> > ERC32_Restore_interrupt() will enable the interrupt even though
> > it was supposed to be masked. This is indeed what happens in
> > DEBUG_puts when polled console I/O is used. In my opinion, the
> > last statement in the macro should be removed - what is your opinion?
> I think the "~" shouldn't be there. I recall that the intent of that line
> is to only return the state of the interrupts you were concerned with.
> Removing the line returns entire state. Given that the value returned
> shuold only be used in conjunction with the map, I suppose either removing
> the ~ or the entire line is correct? I can go either way. Just let me
> know which you think is more correct and the source will change. :)
Hmmm, just removing the '~' should be OK. DEBUG_puts() seems to be the
only user of ERC32_Restore_interrupt() anyway ...
automake:
* I didn't yet touch the cpu subdirectory. I still need some time to
think on how to handle them.
* I probably will wait for the next snapshot before mailing more patches
(I still have some pending), giving you a chance to apply them and me a
chance to become target of the bullets which will probably be aimed at
me after these modifications.
Some Makefile.ins depend on gcc by hard-coded gcc-specific compiler
flags:
-g added to CFLAGS /LDFLAGS in
> find . -name Makefile.in -exec grep -l ' \-g' {} \;
./c/src/lib/libbsp/i386/i386ex/startup/Makefile.in
./c/src/lib/libbsp/i386/pc386/tools/Makefile.in
-Wall added CFLAGS in
> find . -name Makefile.in -exec grep -l ' \-Wall' {} \;
./c/src/exec/score/tools/sh/Makefile.in
Both -g and -Wall should not be used in any Makefile.in (Yes, I know,
tools/sh/Makefile.in was written by me :-).
I'd like to propose to remove these flags from the files mentioned
above.
This patch avoids a warning from the development version of gas.
Hello,
host :
- one for RTEMS it self,
- one for GDB-4.17.
1/ RTEMS patch
This patch adds 2 libraries :
- the Remote Debugger library
--enable-rdbg
rtems_rdbg_initialize ();
2/ GDB-4.17 patch
To connect to a target, use :
And... Debug ;)
it work.
<erik.ivanenko@utoronto.ca> and Eric Valette <valette@crf.canon.fr>.
1) Socket timeout field changed from `short' to `long'. This makes longer
timeouts possible. With a 1 kHz system clock the old system allowed
timeouts only up to a little over 30 seconds! This change is a
slightly cleaned-up version of the patch proposed by Ian Lance Taylor.
2) Major changes to BOOTP/DHCP reply handling. Now supports much of
RFC2132. These changes were done at the request of, and with the
assistance of, Erik Ivanenko.
If you're making changes, you might want to change the network
supplement Essentially just do a global search and replace of BOOTP
with BOOTP/DHCP.
I just happened across the sync_io support in
c/src/exec/score/cpu/unix/cpu.c
(is this documented anywhere?). That looked more useful than the
signal driven I/O I was using before, so I tried it. I ran across a
few bugs in the way it uses select.
Select changes its fd_set arguments, so you can't use global variables
for them. You have to copy them into local variables first.
If select returns -1 with errno set to EINTR, then it has not changed
any of the fd_sets. You can't start looking at them.
When clearing a descriptor, the code has the usual select off by one
error when setting sync_io_nfds.
I don't see how this code could ever have worked correctly.
I have appended a patch for the problems I found.
scripts (make/rtems.cfg)
Testing:
cosmetic things.
Thanks to Rod Barman for this one.
- c/src/exec/score/cpu/powerpc/ppc.h: some small changes
(added ppc403 characteristics like a exception vector prefix
register, some special register definitions). I am quite sure, they
are compatible with the existing sources, although I did not check
- c/src/exec/score/cpu/powerpc/cpu.c: There is one severe
limitation in the exception entries: Due to the current code
arrangement, the "branch absolute" to the ISR handler may only
jump to the first 128MByte or the last 128MByte of the 4GByte
address range. When the ppc403 is running out of ROM, the ROM
functions are located in the last 128MByte (0xFFF00000 and up).
These addresses were not handled correctly (sign reduced) in
"install_raw_handler". The change I added should work on existing
ppc BSPs aswell...
I found that my 68040/68360 test programs would not run even after
I fixed the `wrong BSP' problem.
It seems that there's a bug in the interrupt handling code for
processors with hardware interrupt stacks (e.g. 68040). The wrong
status register was getting pushed on the stack for the `return
from exception' to call _ISR__Dispatch. This ended up making
the context switch code run on the interrupt stack, so interrupt-driven
context switches would always fail.
I guess that no one has tried running any of the RTEMS-4.0 snapshots
on a 68040 machine!
Anyhow, here are the patches for
1) gen68360.cfg --- to fix the `wrong-BSP' problem.
2) m68k/cpu_asm.s --- to fix the hardware interrupt stack problem.
With these patches in place, the network demo programs run on my
68040/68360 system. The paranoia program runs with no failures,
defects nor flaws.
ports.
Eric> NB : there is still a bug on PC386 serial line : exit does not
Eric> flush the remaining output queue. As this is not a bug in the
Eric> driver itself but somewhere in PC386 initialization/termios
Eric> relationship it will be part of another patch.
Eric> NB2 : As Emmanuel excerced the exception hanlder code, while
Eric> porting the SMC driver to the new BSD stack, we found a bug
Eric> in the exception handler : it shall not delete the current
Eric> thread in case we are running at interrupt level. This will
Eric> be part of another patch...
So here is the patch. This patch fixes the two problems mentionned above
+ it use vpath mechanism intead of copying the irq related files in
the right directory. This avoid to compile them each time and is
more homogenous with other Makefiles.
when building the executive source.
Here is a patch that enables to catch exception
and get message before crashing RTEMS :)
It should be generic to any Intel port although enabled
only for pc386 BSP...
[Joel] I fixed the bug I introduced in irq_asm.s...
- Use the "hlt" instruction for the Idle thread,
- Optimise interrupt PATH leadding to thread wakeup,
- Preparation for Intel exception management that should
come before the end of the week...
BSDINSTALL=@INSTALL@
in autoconf.
fixed.
Here is a small patch which allows the m68060 to be used. I have not
tested the FP switching stuff which we know is broken. This is taken
against the libchip snapshot but should merge without problems. If you
have any problems please let me know.
There are other smaller issues such as superscalar enable and cache
control which I have not addressed yet. They are different to all other
m68k processors. These can wait IMO.
inline with the new IRQ structure.
Enabled on the pc386.
old way of setting th cpu family and model string names.
specific register macros and correct code in rtems.s.
Now that Joel told me how to compile outside the tree,
I have found a few more bugs. Here is a small patch
to fix them.
of theses targets...
Here is a pure sh-rtems bug-fix patch.
The defines to enable the network to host conversion macros in
netinet/in.h were missing in sh/cpu.h
sources files.
TARGET_VARIANTS
NOTE:
FINALLY:
to each Makefile.in.
* c/src/exec/score/tools/sh - NEW DIRECTORY - contains shgen
Most of it should be self-explanatory. I am a little bit concerned about
host-dependent features (getopt, floating point libraries). This
shouldn't disturb much now, as this tool should be compileable on all
gnu-based hosts and is only applicable for the sh. But in case somebody
complains, we may need to add autoconf checks or even restructurize
parts of rtems (IMO, rtems needs to be restructurized - remember the
"turning rtems upside down" issue).
