path: root/c/src/exec/score/src/coretod.c (follow)
* Remove, moved to cpukit.Ralf Corsepius2002-07-221-59/+0
* Split Heap and Time of Day Handlers.Joel Sherrill1999-11-021-178/+0
* changed _TOD_Is_set from a function to a boolean variableJoel Sherrill1996-09-061-0/+4
* renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the WatchdogJoel Sherrill1996-05-311-1/+0
| | | | | Handler could timestamp the starting and stopping of timers. Since TOD is built on top of Watchdog, this avoided a circular dependency.
* Insert mode argument to _Watchdog_Insert removed. Now are watchdog timersJoel Sherrill1995-12-011-2/+1
| | | | are automatically activated upon insertion.
* posix support initially addedJoel Sherrill1995-09-261-4/+4
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-15/+15
* Initial revisionJoel Sherrill1995-05-111-0/+236
