* | Remove, moved to cpukit. | Ralf Corsepius | 2002-07-22 | 1 | -62/+0 |
* | 2002-07-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-01 | 1 | -7/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Mega patch merge to change the format of the object IDs to loosen the dependency between the SCORE and the various APIs. There was considerable work to simplify the object name management and it appears that the name_table field is no longer needed. This patch also includes the addition of the internal mutex which is currently only used to protect some types of allocation and deallocation. This significantly can reduce context switch latency under certain circumstances. In particular, some heap/region operations were O(n) and had dispatching disabled. This should help enormously. With this merge, the patch is not as clean as it should be. In particular, the documentation has not been modified to reflect the new object ID layout, the IDs in the test screens are not updated, and _Objects_Get_information needs to be a real routine not inlined. As part of this patch a lot of MP code for thread/proxy blocking was made conditional and cleaned up. * include/Makefile.am, include/rtems/score/coremsg.h, include/rtems/score/coremutex.h, include/rtems/score/coresem.h, include/rtems/score/object.h, include/rtems/score/threadq.h, inline/rtems/score/object.inl, inline/rtems/score/thread.inl, macros/rtems/score/object.inl, src/Makefile.am, src/coremsg.c, src/coremutex.c, src/coresem.c, src/mpci.c, src/objectcomparenameraw.c, src/objectextendinformation.c, src/objectinitializeinformation.c, src/objectnametoid.c, src/thread.c, src/threadclose.c, src/threadget.c, src/threadq.c, src/threadqextractwithproxy.c: Modified as part of above. * include/rtems/score/apimutex.h, src/objectgetnoprotection.c: New files. | ||||
* | Split core message queue and watchdog handler objects into separate files. | Joel Sherrill | 1999-11-02 | 1 | -127/+0 |
* | Added maximum count detection logic. | Joel Sherrill | 1999-11-02 | 1 | -3/+13 |
* | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 1998-11-23 | 1 | -0/+2 |
| | | | | it work. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | invalid use of tcb field resource count | Joel Sherrill | 1996-02-01 | 1 | -1/+0 |
* | added correct use of _Thread_queue_Enter_critical_section | Joel Sherrill | 1995-12-08 | 1 | -1/+1 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -6/+6 |
* | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 1995-09-11 | 1 | -0/+185 |
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. |
