* Mega patch merge to change the format of the object IDs to
loosen the dependency between the SCORE and the various APIs.
There was considerable work to simplify the object name management
and it appears that the name_table field is no longer needed.
This patch also includes the addition of the internal mutex
which is currently only used to protect some types of allocation
and deallocation. This significantly can reduce context
switch latency under certain circumstances. In particular,
some heap/region operations were O(n) and had dispatching
disabled. This should help enormously. With this merge,
the patch is not as clean as it should be. In particular,
the documentation has not been modified to reflect the new object
ID layout, the IDs in the test screens are not updated, and
_Objects_Get_information needs to be a real routine not inlined.
As part of this patch a lot of MP code for thread/proxy blocking
was made conditional and cleaned up.
* include/Makefile.am, include/rtems/score/coremsg.h,
include/rtems/score/coremutex.h, include/rtems/score/coresem.h,
include/rtems/score/object.h, include/rtems/score/threadq.h,
inline/rtems/score/object.inl, inline/rtems/score/thread.inl,
macros/rtems/score/object.inl, src/Makefile.am, src/coremsg.c,
src/coremutex.c, src/coresem.c, src/mpci.c,
src/objectcomparenameraw.c, src/objectextendinformation.c,
src/objectinitializeinformation.c, src/objectnametoid.c,
src/thread.c, src/threadclose.c, src/threadget.c, src/threadq.c,
src/threadqextractwithproxy.c: Modified as part of above.
* include/rtems/score/apimutex.h, src/objectgetnoprotection.c: New
files.
* include/rtems/score/thread.h, inline/rtems/score/thread.inl,
src/threaddispatch.c, src/threadinitialize.c:
Move the C library re-enterrant support directly into
the thread dispatch code. RTEMS needs libc and so requiring
libc to use a user extension with its overhead is not the best
solution. This patch lowers the overhead to 2 pointer moves.
the thread handler (IDLE), MPCI object (SYSI now MP Receive)
and initialize_executive_early (IO initialization). The SYSI task
no longer exists in a single processor configuration. This reduces
single processor Workspace requirements by a TCB and a stack which
is often larger than the minimum stack size. Moving the IO initialization
plus accompanying BSP hooks eliminated an initialization ordering problem
in which a global task could be created before the MPCI was initialized.
like signal dispatching.
