path: root/c/src/exec/sapi/headers/init.h (follow)
* Moved around per Ralf Corsepius as preparation for automakeJoel Sherrill1998-12-151-110/+0
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-2/+10
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-0/+1
* Initial revisionJoel Sherrill1995-05-111-0/+101
