path: root/c/src/exec/rtems/optman/no-rtmon.c (follow)
* 2002-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-071-116/+0
| | | | | | | | * optman/, optman/.cvsignore, optman/Makefile.am, optman/no-dpmem.c, optman/no-event.c, optman/no-mp.c, optman/no-msg.c, optman/no-part.c, optman/no-region.c, optman/no-rtmon.c, optman/no-sem.c, optman/no-signal.c, optman/no-timer.c: Removed entire contents of optman/ directory since it has been moved.
* modified to generate fatal error when an unconfigured directive is invoked.Joel Sherrill1996-04-191-1/+37
* posix support initially addedJoel Sherrill1995-09-261-3/+3
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-9/+12
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-2/+2
* Initial revisionJoel Sherrill1995-05-111-0/+78
