* src/regiongetinfo.c, include/rtems/rtems/region.h,
include/rtems/rtems/types.h, src/Makefile.am: Added
region_get_information() and information control block.
* src/regiongetinfo.c: New file.
it work.
like signal dispatching.
correct Information block.
