path: root/c/src/exec/posix/src/semaphore.c (follow)
* Remove, moved to cpukit.Ralf Corsepius2002-07-221-54/+0
* 2002-07-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-051-1/+1
| | | | | | | * include/rtems/posix/cancel.h, src/cancel.c, src/cancelrun.c, src/mqueue.c, src/pthread.c, src/semaphore.c, src/setcancelstate.c, src/setcanceltype.c, src/testcancel.c: Per PR164, corrected the behavior of thread cancellation and did some cleanup as a side-effect.
* 2002-07-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-011-7/+12
| | | | | | | | | | | | | | | | | | | | | | | | * Mega patch merge to change the format of the object IDs to loosen the dependency between the SCORE and the various APIs. There was considerable work to simplify the object name management and it appears that the name_table field is no longer needed. This patch also includes the addition of the internal mutex which is currently only used to protect some types of allocation and deallocation. This significantly can reduce context switch latency under certain circumstances. In particular, some heap/region operations were O(n) and had dispatching disabled. This should help enormously. With this merge, the patch is not as clean as it should be. In particular, the documentation has not been modified to reflect the new object ID layout, the IDs in the test screens are not updated, and _Objects_Get_information needs to be a real routine not inlined. As part of this patch a lot of MP code for thread/proxy blocking was made conditional and cleaned up. * include/rtems/posix/key.h, src/cond.c, src/condinit.c, src/intr.c, src/key.c, src/keycreate.c, src/keydelete.c, src/killinfo.c, src/mqueue.c, src/mqueuecreatesupp.c, src/mutex.c, src/mutexinit.c, src/psignal.c, src/pthread.c, src/semaphore.c, src/semaphorecreatesupp.c: Modified as part of above.
* 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-241-0/+4
| | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-301-1/+1
| | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs.
* Split the POSIX semaphore manager into multiple files.Joel Sherrill1999-11-021-584/+0
* Removed warnings.Joel Sherrill1999-11-021-2/+2
* Now much closer to working.Joel Sherrill1999-11-021-7/+61
* Now compiles and is included in normal build even though it is untested.Joel Sherrill1999-04-151-32/+36
| | | | Added multiprocessing conditional.
* changed code which set errno and then returned -1 to use the macroJoel Sherrill1996-06-071-8/+4
| | | | set_errno_and_return_minus_one.
* renamed _POSIX_Time_Spec_to_interval to _POSIX_Timespec_to_intervalJoel Sherrill1996-06-031-1/+1
* comment clean upJoel Sherrill1996-05-291-2/+1
* fixed missing CVS IDsJoel Sherrill1995-10-061-0/+1
* posix support initially addedJoel Sherrill1995-09-261-0/+575
