* | Remove, moved to cpukit. | Ralf Corsepius | 2002-07-22 | 1 | -79/+0 |
* | 2001-04-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-04-26 | 1 | -3/+20 |
| | | | | | | | | | | * include/rtems/posix/mqueue.h, inline/rtems/posix/mqueue.inl, src/mqueue.c, src/mqueueclose.c, src/mqueuecreatesupp.c, src/mqueuegetattr.c, src/mqueuenotify.c, src/mqueueopen.c, src/mqueuerecvsupp.c, src/mqueuesendsupp.c, src/mqueuesetattr.c: Per PR81 reworked to add a message queue descriptor separate from the underlying message queue. This allows non-blocking to follow the "open" not the underlying queue. | ||||
* | 2002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-04 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * src/clockgetres.c: Apply rtems_set_errno_and_return_minus_one. * src/clockgettime.c: Apply rtems_set_errno_and_return_minus_one. * src/clocksettime.c: Apply rtems_set_errno_and_return_minus_one. * src/killinfo.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueclose.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuecreatesupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuegetattr.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuenotify.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueopen.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuerecvsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuesendsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuesetattr.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueunlink.c: Apply rtems_set_errno_and_return_minus_one. * src/nanosleep.c: Apply rtems_set_errno_and_return_minus_one. * src/pthreadkill.c: Apply rtems_set_errno_and_return_minus_one. * src/pthreadsigmask.c: Apply rtems_set_errno_and_return_minus_one. * src/ptimer1.c: Apply rtems_set_errno_and_return_minus_one. * src/sched.c: Apply rtems_set_errno_and_return_minus_one. * src/semaphorecreatesupp.c: Apply rtems_set_errno_and_return_minus_one. * src/semaphorewaitsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/semclose.c: Apply rtems_set_errno_and_return_minus_one. * src/semdestroy.c: Apply rtems_set_errno_and_return_minus_one. * src/semgetvalue.c: Apply rtems_set_errno_and_return_minus_one. * src/seminit.c: Apply rtems_set_errno_and_return_minus_one. * src/semopen.c: Apply rtems_set_errno_and_return_minus_one. * src/sempost.c: Apply rtems_set_errno_and_return_minus_one. * src/semunlink.c: Apply rtems_set_errno_and_return_minus_one. * src/setpgid.c: Apply rtems_set_errno_and_return_minus_one. * src/setsid.c: Apply rtems_set_errno_and_return_minus_one. * src/sigaction.c: Apply rtems_set_errno_and_return_minus_one. * src/sigaddset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigdelset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigemptyset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigfillset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigismember.c: Apply rtems_set_errno_and_return_minus_one. * src/sigpending.c: Apply rtems_set_errno_and_return_minus_one. * src/sigtimedwait.c: Apply rtems_set_errno_and_return_minus_one. * src/utsname.c: Apply rtems_set_errno_and_return_minus_one. | ||||
* | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-24 | 1 | -0/+4 |
| | | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support. | ||||
* | 2000-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-08-30 | 1 | -1/+1 |
| | | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs. | ||||
* | + Fixed errno response to match the POSIX manual. | Jennifer Averett | 1999-12-23 | 1 | -1/+1 |
* | Split mqueue.c into a variety of files. | Joel Sherrill | 1999-11-02 | 1 | -0/+58 |
