index
4.11
4.8
4.9
5
master
RTEMS Kernel, file-systems, drivers, BSPs, samples, and testsuite.
devel@rtems.org
summary
refs
log
tree
commit
diff
stats
log msg
author
committer
range
path:
root
src
exec
posix
include
posix
pthread.h
follow
Commit message (
Collapse
Author
Age
Lines
Remove, moved to cpukit.
2002-07-22
1
-150
+0
Updated copyright notice.
Joel Sherrill
1999-11-17
1
-2
+1
Added enough prototypes to allow most of POSIX Threads Manager to be
Joel Sherrill
1999-01-25
1
-0
+26
split into multiple files.
Added --disable-multiprocessing flag and modified a lot of files to make
Joel Sherrill
1998-11-23
1
-0
+2
it work.
updated copyright to 1998
Joel Sherrill
1998-02-17
1
-1
+1
Fixed typo in the pointer to the license terms.
Joel Sherrill
1997-10-08
1
-2
+2
headers updated to reflect new style copyright notice as part
Joel Sherrill
1997-04-22
1
-5
+5
moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would be
Joel Sherrill
1996-09-08
1
-0
+2
visible to other files.
switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"
Joel Sherrill
1996-07-03
1
-4
+4
deleted POSIX threads typedef masking Thread_Control
Joel Sherrill
1996-06-03
1
-11
+5
posix initialization threads table was misnamed "posix initialization
Joel Sherrill
1996-05-29
1
-7
+7
tasks table"
first cut at pthread_create
Joel Sherrill
1996-05-29
1
-3
+3
split the inclusion of "EXTERN" data based on whether it was sapi,
Joel Sherrill
1996-05-28
1
-3
+3
added initial set of api extension callouts
Joel Sherrill
1996-05-28
1
-1
+15
posix support initially added
Joel Sherrill
1995-09-26
1
-0
+113
