* | Moved around per Ralf Corsepius as preparation for automake | Joel Sherrill | 1998-12-15 | 21 | -2129/+0 |
* | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 1998-11-23 | 6 | -3/+17 |
| | | | | it work. | ||||
* | Changed __POSIX_SIGNALS_h to __RTEMS_POSIX_SIGNALS_h to avoid conflict with | Joel Sherrill | 1998-04-27 | 1 | -2/+7 |
| | | | | | | | the system signals.h file. Moved POSIX_signals_Siginfo_node type definition to this file to allow confdefs.h to know the size per queued signal. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 15 | -15/+15 |
* | Big patch form Ralf Corsepius described in this email: | Joel Sherrill | 1998-01-30 | 1 | -4/+2 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Here is the result of my nightly work to get RTEMS_ROOT=$srcdir working with different shells and relative/absolute paths. What I did is relatively simple in principle: Instead of setting RTEMS_ROOT in configure.in and then let configure substitute @RTEMS_ROOT@ inside the Makefiles, I now let each Makefile set RTEMS_ROOT from each Makefile's @top_srcdir@ value. The difference is subtile, but with enormous side effects: - If RTEMS_ROOT is set in configure, then the same single value will be propagated to all Makefiles. This breaks using relative paths, as the relative path to the root of the source tree is used inside of all subdirectory Makefiles. - Now each Makefile.in sets RTEMS_ROOT = @top_srcdir@. top_srcdir is computed individually by configure for each single Makefile.in, hereby receiving the correct value, no matter if relative or absolute paths are used. To get this working, I needed to remove setting RTEMS_ROOT from target.cfg.in, because this overrides the value of RTEMS_ROOT from each individual Makefile. Furthermore, I removed RTEMS_CUSTOM from the Makefiles and replaced all "include $(RTEMS_CUSTOM)" directives with"include $(RTEMS_ROOT)/make/custom/$(RTEMS_BSP)". Perhaps you don't like this, but I think, to have one variable less is clearer and easier to understand than having several variables refering to the next one. I enclose a small patch to this mail, which - fixes the config.h problem (to finally clearify misunderstands) - removes assignment/subsitution of RTEMS_ROOT from configure.in - contains a workaround for the application Makefile's RTEMS_ROOT problem (reported by Eric) - removes some unused lines from the toplevel Makefile.in - removes assignment of RTEMS_ROOT from make/target.cfg.in | ||||
* | Removed CONFIG_DIR and PROJECT_HOME directories. | Joel Sherrill | 1998-01-20 | 1 | -1/+1 |
* | Modified a lot of files to take a first cut at supporting building from | Joel Sherrill | 1997-12-10 | 1 | -1/+4 |
| | | | | | any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32). | ||||
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 15 | -30/+30 |
* | Removed include directory at "build" point and the link of this directory | Joel Sherrill | 1997-10-08 | 1 | -1/+1 |
| | | | | | | to lib/include. Went to using a PROJECT_INCLUDE variable. | ||||
* | Changed name from entry to thread_entry to be more compatible with | Joel Sherrill | 1997-07-09 | 1 | -1/+1 |
| | | | | Ada interface where entry is a keyword. | ||||
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 15 | -75/+75 |
* | Reduced number of POSIX thread priorities from 255 to 254 to avoid conflicts | Joel Sherrill | 1997-04-15 | 1 | -1/+7 |
| | | | | | of lowest priority with the RTEMS IDLE thread. This was causing the lowest priority GNAT Ada task to never run. | ||||
* | This set of changes is the build of what was required to convert to | Joel Sherrill | 1997-04-01 | 1 | -0/+33 |
| | | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. | ||||
* | added prototype for _POSIX_Timespec_subtract | Joel Sherrill | 1996-09-17 | 1 | -0/+11 |
* | moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would be | Joel Sherrill | 1996-09-08 | 1 | -0/+2 |
| | | | | visible to other files. | ||||
* | added constant to indicate there is no mutex associated with this | Joel Sherrill | 1996-08-15 | 1 | -0/+7 |
| | | | | condition variable | ||||
* | mutex.h: removes the promotion of core status code to POSXI status codes | Mark Johannes | 1996-08-12 | 1 | -12/+0 |
* | mutex.h: promoted out _POSIX_Mutex_From_core_mutex_status | Mark Johannes | 1996-08-12 | 1 | -0/+12 |
* | added ss_high_priority field to support sporadic server. | Joel Sherrill | 1996-08-08 | 1 | -0/+1 |
* | switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE" | Joel Sherrill | 1996-07-03 | 8 | -32/+32 |
* | fields for init threads stuff said tasks. | Joel Sherrill | 1996-06-14 | 1 | -2/+2 |
* | config.h: added maximum_queued_signals. | Joel Sherrill | 1996-06-13 | 2 | -1/+4 |
| | | | | psignal.h: fixed typo. | ||||
* | added prototype for manager initialization routine. | Joel Sherrill | 1996-06-13 | 1 | -0/+2 |
* | deleted field for signals_global_pending. | Joel Sherrill | 1996-06-11 | 1 | -1/+0 |
* | new file. | Joel Sherrill | 1996-06-11 | 1 | -1/+1 |
* | added psignal.h | Joel Sherrill | 1996-06-10 | 1 | -0/+13 |
* | *** empty log message *** | Joel Sherrill | 1996-06-10 | 1 | -1/+1 |
* | new file | Joel Sherrill | 1996-06-07 | 1 | -0/+20 |
* | in newlib now | Joel Sherrill | 1996-06-06 | 1 | -0/+4 |
* | added Sporadic_timer field to support sporadic server | Joel Sherrill | 1996-06-06 | 1 | -0/+1 |
* | added comments to priority.h to document the definition of posix priority | Joel Sherrill | 1996-06-05 | 2 | -2/+6 |
| | | | | | | and how it corresponds to rtems core priority. Schedule was renamed schedparam | ||||
* | added scheduling policy and parameter information | Joel Sherrill | 1996-06-04 | 1 | -0/+3 |
* | added thread queue for list of threads waiting to join. | Joel Sherrill | 1996-06-03 | 1 | -0/+2 |
* | deleted POSIX threads typedef masking Thread_Control | Joel Sherrill | 1996-06-03 | 2 | -11/+6 |
* | renamed _POSIX_Time_Spec_to_interval to _POSIX_Timespec_to_interval | Joel Sherrill | 1996-06-03 | 1 | -1/+15 |
* | added constant for seconds between posix epoch (1970) and rtems epoch (1988). | Joel Sherrill | 1996-06-03 | 1 | -0/+11 |
| | | | | Formerly this constant was in the file src/time.c. | ||||
* | commented out cancel handlers related items. | Joel Sherrill | 1996-05-31 | 1 | -0/+3 |
* | posix initialization threads table was misnamed "posix initialization | Joel Sherrill | 1996-05-29 | 2 | -14/+14 |
| | | | | tasks table" | ||||
* | first cut at pthread_create | Joel Sherrill | 1996-05-29 | 1 | -3/+3 |
* | added entry point for posix initialization threads to the posix initialization | Joel Sherrill | 1996-05-29 | 1 | -2/+8 |
| | | | | threads table structure | ||||
* | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 1996-05-28 | 8 | -10/+48 |
| | | | | score, rtems api, or posix api related. | ||||
* | added initial set of api extension callouts | Joel Sherrill | 1996-05-28 | 2 | -2/+16 |
* | commented out interrupt support | Joel Sherrill | 1996-05-28 | 1 | -0/+2 |
* | added maximum keys | Joel Sherrill | 1996-05-28 | 1 | -0/+1 |
* | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 1 | -0/+51 |
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 1 | -2/+1 |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 2 | -0/+2 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 16 | -0/+1862 |
