* | Remove, moved to cpukit. | Ralf Corsepius | 2002-07-22 | 1 | -41/+0 |
* | 2001-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-22 | 1 | -0/+4 |
| | | | | | | | * configure.in: Add src/imfs/config.h * src/imfs/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/imfs/.cvsignore: Add config.h and stamp-h * src/imfs/*.c: Add config.h support. | ||||
* | Unmount was failing as a side-effect of splitting the rmnod handler | Joel Sherrill | 1999-11-05 | 1 | -1/+1 |
| | | | | and not handling every case properly. | ||||
* | The object memfile.o was being included in the miniIMFS even though it | Joel Sherrill | 1999-11-02 | 1 | -1/+1 |
| | | | | | | | should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS. | ||||
* | Moved the rmnod callback from the operations table to the handler table. | Jennifer Averett | 1999-10-29 | 1 | -1/+2 |
* | New files created by split of old imfs_handlers.c. | Joel Sherrill | 1999-10-26 | 1 | -0/+37 |
