* | Remove, moved to cpukit. | Ralf Corsepius | 2002-07-22 | 1 | -12/+0 |
* | 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-06-17 | 1 | -3/+3 |
| | | | | | | | | | * src/dosfs/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/imfs/Makefile.am: Include $(top_srcdir)/../automake/*.am. * Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * wrapup/Makefile.am: Include $(top_srcdir)/../automake/*.am. | ||||
* | 2002-05-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-05-28 | 1 | -3/+3 |
| | | | | | | | | | | Move from c/src/libfs to c/src/exec/libfs * configure.ac: Reflect move. * Makefile.am: Ditto. * src/Makefile.am: Ditto. * src/dosfs/Makefile.am: Ditto. * src/imfs/Makefile.am: Ditto. * wrapup/Makefile.am: Ditto. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -1/+0 |
| | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * src/dosfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/imfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-09 | 1 | -1/+1 |
| | | | | * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | ||||
* | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-02 | 1 | -1/+1 |
| | | | | * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | ||||
* | 2000-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-24 | 1 | -1/+1 |
| | | | | | | | | * Makefile.am, configure.in: Introduce GNU canonicalization to libfs/. The approach is currently a bit of a hack as GNU canonicalization does not support the per-BSP build some of the other directories require. As more of the tree is converted, this will become less of an issue. | ||||
* | 2000-10-18 Chris Johns <ccj@acm.org> | Joel Sherrill | 2000-10-18 | 1 | -0/+13 |
* libfs created. * src, src/imfs, wrapup: New directories. * ChangeLog, Makefile.am, README, configure.in, src/Makefile.am, wrapup/Makefile.am: New files. * src/imfs/deviceio.c, src/imfs/imfs_getchild.c, src/imfs/imfs_readlink.c, src/imfs/imfs.h, src/imfs/imfs_gtkn.c, src/imfs/imfs_rmnod.c, src/imfs/imfs_chown.c, src/imfs/imfs_handlers_device.c, src/imfs/imfs_stat.c, src/imfs/imfs_creat.c, src/imfs/imfs_handlers_directory.c, src/imfs/imfs_symlink.c, src/imfs/imfs_debug.c, src/imfs/imfs_handlers_link.c, src/imfs/imfs_unixstub.c, src/imfs/imfs_directory.c, src/imfs/imfs_handlers_memfile.c, src/imfs/imfs_unlink.c, src/imfs/imfs_eval.c, src/imfs/imfs_init.c, src/imfs/imfs_unmount.c, src/imfs/imfs_fchmod.c, src/imfs/imfs_initsupp.c, src/imfs/imfs_utime.c, src/imfs/imfs_fcntl.c, src/imfs/imfs_link.c, src/imfs/memfile.c, src/imfs/imfs_fdatasync.c, src/imfs/imfs_mknod.c, src/imfs/miniimfs_init.c, src/imfs/imfs_free.c, src/imfs/imfs_mount.c, src/imfs/imfs_fsunmount.c, src/imfs/imfs_ntype.c: New files. Moved from libc. |
