path: root/c/src/ada-tests/mptests/mp11/node1/mp11_node1.adb (follow)
* ada-tests: Move to testsuites/adaSebastian Huber2017-10-121-56/+0
| | | | | | | This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079.
* 2011-02-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-02-161-3/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ada-tests/mptests/mp01/mp01.adb, ada-tests/mptests/mp01/mptest.adb, ada-tests/mptests/mp01/mptest.ads, ada-tests/mptests/mp01/node1/mp01_node1.adb, ada-tests/mptests/mp01/node2/mp01_node2.adb, ada-tests/mptests/mp02/mptest.adb, ada-tests/mptests/mp02/mptest.ads, ada-tests/mptests/mp02/node1/mp02_node1.adb, ada-tests/mptests/mp02/node2/mp02_node2.adb, ada-tests/mptests/mp03/mptest.adb, ada-tests/mptests/mp03/mptest.ads, ada-tests/mptests/mp03/node1/mp03_node1.adb, ada-tests/mptests/mp03/node2/mp03_node2.adb, ada-tests/mptests/mp04/mptest.adb, ada-tests/mptests/mp04/mptest.ads, ada-tests/mptests/mp04/node1/mp04_node1.adb, ada-tests/mptests/mp04/node2/mp04_node2.adb, ada-tests/mptests/mp05/mptest.adb, ada-tests/mptests/mp05/mptest.ads, ada-tests/mptests/mp05/node1/mp05_node1.adb, ada-tests/mptests/mp05/node2/mp05_node2.adb, ada-tests/mptests/mp06/mptest.adb, ada-tests/mptests/mp06/mptest.ads, ada-tests/mptests/mp06/node1/mp06_node1.adb, ada-tests/mptests/mp06/node2/mp06_node2.adb, ada-tests/mptests/mp07/mptest.adb, ada-tests/mptests/mp07/mptest.ads, ada-tests/mptests/mp07/node1/mp07_node1.adb, ada-tests/mptests/mp07/node2/mp07_node2.adb, ada-tests/mptests/mp08/mptest.adb, ada-tests/mptests/mp08/mptest.ads, ada-tests/mptests/mp08/node1/mp08_node1.adb, ada-tests/mptests/mp08/node2/mp08_node2.adb, ada-tests/mptests/mp09/mptest.adb, ada-tests/mptests/mp09/mptest.ads, ada-tests/mptests/mp09/node1/mp09_node1.adb, ada-tests/mptests/mp09/node2/mp09_node2.adb, ada-tests/mptests/mp10/mptest.adb, ada-tests/mptests/mp10/mptest.ads, ada-tests/mptests/mp10/node1/mp10_node1.adb, ada-tests/mptests/mp10/node2/mp10_node2.adb, ada-tests/mptests/mp11/mptest.adb, ada-tests/mptests/mp11/mptest.ads, ada-tests/mptests/mp11/node1/mp11_node1.adb, ada-tests/mptests/mp11/node2/mp11_node2.adb, ada-tests/mptests/mp12/mptest.adb, ada-tests/mptests/mp12/mptest.ads, ada-tests/mptests/mp12/node1/mp12_node1.adb, ada-tests/mptests/mp12/node2/mp12_node2.adb, ada-tests/mptests/mp13/mptest.adb, ada-tests/mptests/mp13/mptest.ads, ada-tests/mptests/mp13/node1/mp13_node1.adb, ada-tests/mptests/mp13/node2/mp13_node2.adb, ada-tests/mptests/mp14/mptest.adb, ada-tests/mptests/mp14/mptest.ads, ada-tests/mptests/mp14/node1/mp14_node1.adb, ada-tests/mptests/mp14/node2/mp14_node2.adb, ada-tests/samples/base_mp/mptest.adb, ada-tests/samples/base_mp/mptest.ads, ada-tests/samples/base_sp/base_sp.adb, ada-tests/samples/base_sp/sptest.adb, ada-tests/samples/base_sp/sptest.ads, ada-tests/samples/hello/hello.adb, ada-tests/samples/hello/sptest.adb, ada-tests/samples/hello/sptest.ads, ada-tests/samples/nsecs/nsecs.adb, ada-tests/samples/nsecs/sptest.adb, ada-tests/samples/nsecs/sptest.ads, ada-tests/samples/ticker/sptest.adb, ada-tests/samples/ticker/sptest.ads, ada-tests/samples/ticker/ticker.adb, ada-tests/sptests/sp01/sp01.adb, ada-tests/sptests/sp01/sptest.adb, ada-tests/sptests/sp01/sptest.ads, ada-tests/sptests/sp02/sp02.adb, ada-tests/sptests/sp02/sptest.adb, ada-tests/sptests/sp02/sptest.ads, ada-tests/sptests/sp03/sp03.adb, ada-tests/sptests/sp03/sptest.adb, ada-tests/sptests/sp03/sptest.ads, ada-tests/sptests/sp04/sp04.adb, ada-tests/sptests/sp04/sptest.adb, ada-tests/sptests/sp04/sptest.ads, ada-tests/sptests/sp05/sp05.adb, ada-tests/sptests/sp05/sptest.adb, ada-tests/sptests/sp05/sptest.ads, ada-tests/sptests/sp06/sp06.adb, ada-tests/sptests/sp06/sptest.adb, ada-tests/sptests/sp06/sptest.ads, ada-tests/sptests/sp07/sp07.adb, ada-tests/sptests/sp07/sptest.adb, ada-tests/sptests/sp07/sptest.ads, ada-tests/sptests/sp08/sp08.adb, ada-tests/sptests/sp08/sptest.adb, ada-tests/sptests/sp08/sptest.ads, ada-tests/sptests/sp09/sp09.adb, ada-tests/sptests/sp09/sptest.adb, ada-tests/sptests/sp09/sptest.ads, ada-tests/sptests/sp11/sp11.adb, ada-tests/sptests/sp11/sptest.adb, ada-tests/sptests/sp11/sptest.ads, ada-tests/sptests/sp12/sp12.adb, ada-tests/sptests/sp12/sptest.adb, ada-tests/sptests/sp12/sptest.ads, ada-tests/sptests/sp13/sp13.adb, ada-tests/sptests/sp13/sptest.adb, ada-tests/sptests/sp13/sptest.ads, ada-tests/sptests/sp14/sp14.adb, ada-tests/sptests/sp14/sptest.adb, ada-tests/sptests/sp14/sptest.ads, ada-tests/sptests/sp15/sp15.adb, ada-tests/sptests/sp15/sptest.adb, ada-tests/sptests/sp15/sptest.ads, ada-tests/sptests/sp16/sp16.adb, ada-tests/sptests/sp16/sptest.adb, ada-tests/sptests/sp16/sptest.ads, ada-tests/sptests/sp17/sp17.adb, ada-tests/sptests/sp17/sptest.adb, ada-tests/sptests/sp17/sptest.ads, ada-tests/sptests/sp19/sp19.adb, ada-tests/sptests/sp19/sptest.adp, ada-tests/sptests/sp19/sptest.ads, ada-tests/sptests/sp20/sp20.adb, ada-tests/sptests/sp20/sptest.adb, ada-tests/sptests/sp20/sptest.ads, ada-tests/sptests/sp22/sp22.adb, ada-tests/sptests/sp22/sptest.adb, ada-tests/sptests/sp22/sptest.ads, ada-tests/sptests/sp23/sp23.adb, ada-tests/sptests/sp23/sptest.adb, ada-tests/sptests/sp23/sptest.ads, ada-tests/sptests/sp24/sp24.adb, ada-tests/sptests/sp24/sptest.adb, ada-tests/sptests/sp24/sptest.ads, ada-tests/sptests/sp25/sp25.adb, ada-tests/sptests/sp25/sptest.adb, ada-tests/sptests/sp25/sptest.ads, ada-tests/support/test_support.adb, ada-tests/tmtests/tm01/tm01.adb, ada-tests/tmtests/tm01/tmtest.adb, ada-tests/tmtests/tm01/tmtest.ads, ada-tests/tmtests/tm02/tm02.adb, ada-tests/tmtests/tm02/tmtest.adb, ada-tests/tmtests/tm02/tmtest.ads, ada-tests/tmtests/tm03/tm03.adb, ada-tests/tmtests/tm03/tmtest.adb, ada-tests/tmtests/tm03/tmtest.ads, ada-tests/tmtests/tm04/tm04.adb, ada-tests/tmtests/tm04/tmtest.adb, ada-tests/tmtests/tm04/tmtest.ads, ada-tests/tmtests/tm05/tm05.adb, ada-tests/tmtests/tm05/tmtest.adb, ada-tests/tmtests/tm05/tmtest.ads, ada-tests/tmtests/tm06/tm06.adb, ada-tests/tmtests/tm06/tmtest.adb, ada-tests/tmtests/tm06/tmtest.ads, ada-tests/tmtests/tm07/tm07.adb, ada-tests/tmtests/tm07/tmtest.adb, ada-tests/tmtests/tm07/tmtest.ads, ada-tests/tmtests/tm08/tm08.adb, ada-tests/tmtests/tm08/tmtest.adb, ada-tests/tmtests/tm08/tmtest.ads, ada-tests/tmtests/tm09/tm09.adb, ada-tests/tmtests/tm09/tmtest.adb, ada-tests/tmtests/tm09/tmtest.ads, ada-tests/tmtests/tm10/tm10.adb, ada-tests/tmtests/tm10/tmtest.adb, ada-tests/tmtests/tm10/tmtest.ads, ada-tests/tmtests/tm11/tm11.adb, ada-tests/tmtests/tm11/tmtest.adb, ada-tests/tmtests/tm11/tmtest.ads, ada-tests/tmtests/tm12/tm12.adb, ada-tests/tmtests/tm12/tmtest.adb, ada-tests/tmtests/tm12/tmtest.ads, ada-tests/tmtests/tm13/tm13.adb, ada-tests/tmtests/tm13/tmtest.adb, ada-tests/tmtests/tm13/tmtest.ads, ada-tests/tmtests/tm14/tm14.adb, ada-tests/tmtests/tm14/tmtest.adb, ada-tests/tmtests/tm14/tmtest.ads, ada-tests/tmtests/tm15/tm15.adb, ada-tests/tmtests/tm15/tmtest.adb, ada-tests/tmtests/tm15/tmtest.ads, ada-tests/tmtests/tm16/tm16.adb, ada-tests/tmtests/tm16/tmtest.adb, ada-tests/tmtests/tm16/tmtest.ads, ada-tests/tmtests/tm17/tm17.adb, ada-tests/tmtests/tm17/tmtest.adb, ada-tests/tmtests/tm17/tmtest.ads, ada-tests/tmtests/tm18/tm18.adb, ada-tests/tmtests/tm18/tmtest.adb, ada-tests/tmtests/tm18/tmtest.ads, ada-tests/tmtests/tm19/tm19.adb, ada-tests/tmtests/tm19/tmtest.adb, ada-tests/tmtests/tm19/tmtest.ads, ada-tests/tmtests/tm20/tm20.adb, ada-tests/tmtests/tm20/tmtest.adb, ada-tests/tmtests/tm20/tmtest.ads, ada-tests/tmtests/tm21/tm21.adb, ada-tests/tmtests/tm21/tmtest.adb, ada-tests/tmtests/tm21/tmtest.ads, ada-tests/tmtests/tm22/tm22.adb, ada-tests/tmtests/tm22/tmtest.adb, ada-tests/tmtests/tm22/tmtest.ads, ada-tests/tmtests/tm23/tm23.adb, ada-tests/tmtests/tm23/tmtest.adb, ada-tests/tmtests/tm23/tmtest.ads, ada-tests/tmtests/tm24/tm24.adb, ada-tests/tmtests/tm24/tmtest.adb, ada-tests/tmtests/tm24/tmtest.ads, ada-tests/tmtests/tm25/tm25.adb, ada-tests/tmtests/tm25/tmtest.adb, ada-tests/tmtests/tm25/tmtest.ads, ada-tests/tmtests/tm28/tm28.adb, ada-tests/tmtests/tm28/tmtest.adb, ada-tests/tmtests/tm28/tmtest.ads, ada-tests/tmtests/tm29/tm29.adb, ada-tests/tmtests/tm29/tmtest.adb, ada-tests/tmtests/tm29/tmtest.ads, ada-tests/tmtests/tmck/tmck.adb, ada-tests/tmtests/tmck/tmtest.adb, ada-tests/tmtests/tmck/tmtest.ads, ada-tests/tmtests/tmoverhd/dummy_rtems.adb, ada-tests/tmtests/tmoverhd/dummy_rtems.ads, ada-tests/tmtests/tmoverhd/tmoverhd.adb, ada-tests/tmtests/tmoverhd/tmtest.adb, ada-tests/tmtests/tmoverhd/tmtest.ads: Account for RTEMS binding child package rework. Eliminate all warnings.
* 2009-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-12-141-1/+2
| | | | | | | | | | | | | | | | | | | | | * mptests/mp01/node1/mp01_node1.adb, mptests/mp01/node2/mp01_node2.adb, mptests/mp02/node1/mp02_node1.adb, mptests/mp02/node2/mp02_node2.adb, mptests/mp03/node1/mp03_node1.adb, mptests/mp03/node2/mp03_node2.adb, mptests/mp04/node1/mp04_node1.adb, mptests/mp04/node2/mp04_node2.adb, mptests/mp05/mptest.adb, mptests/mp05/node1/mp05_node1.adb, mptests/mp05/node2/mp05_node2.adb, mptests/mp06/node1/mp06_node1.adb, mptests/mp06/node2/mp06_node2.adb, mptests/mp07/node1/mp07_node1.adb, mptests/mp07/node2/mp07_node2.adb, mptests/mp08/node1/mp08_node1.adb, mptests/mp08/node2/mp08_node2.adb, mptests/mp09/node1/mp09_node1.adb, mptests/mp09/node2/mp09_node2.adb, mptests/mp10/node1/mp10_node1.adb, mptests/mp10/node2/mp10_node2.adb, mptests/mp11/node1/mp11_node1.adb, mptests/mp11/node2/mp11_node2.adb, mptests/mp12/node1/mp12_node1.adb, mptests/mp12/node2/mp12_node2.adb, mptests/mp13/node1/mp13_node1.adb, mptests/mp13/node2/mp13_node2.adb, mptests/mp14/mptest.adb, mptests/mp14/node1/mp14_node1.adb, mptests/mp14/node2/mp14_node2.adb, sptests/sp09/sptest.adb, sptests/sp11/sptest.adb, sptests/sp13/sptest.adb, sptests/sp16/sptest.adb, support/test_support.adb: Lines are now all less than 80 columns.
* 2007-10-03 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-10-031-0/+56
* mptests/mp01/node1/Makefile.am, mptests/mp01/node2/Makefile.am, mptests/mp02/node1/Makefile.am, mptests/mp02/node2/Makefile.am, mptests/mp03/node1/Makefile.am, mptests/mp03/node2/Makefile.am, mptests/mp04/node1/Makefile.am, mptests/mp04/node2/Makefile.am, mptests/mp05/node1/Makefile.am, mptests/mp05/node2/Makefile.am, mptests/mp06/node1/Makefile.am, mptests/mp06/node2/Makefile.am, mptests/mp07/node1/Makefile.am, mptests/mp07/node2/Makefile.am, mptests/mp08/node1/Makefile.am, mptests/mp08/node2/Makefile.am, mptests/mp09/node1/Makefile.am, mptests/mp09/node2/Makefile.am, mptests/mp10/node1/Makefile.am, mptests/mp10/node2/Makefile.am, mptests/mp11/node1/Makefile.am, mptests/mp11/node2/Makefile.am, mptests/mp12/node1/Makefile.am, mptests/mp12/node2/Makefile.am, mptests/mp13/node1/Makefile.am, mptests/mp13/node2/Makefile.am, mptests/mp14/node1/Makefile.am, mptests/mp14/node2/Makefile.am: Basic build structure should now be correct. The remaining issues should be test specific. * mptests/mp01/config_base.h, mptests/mp01/node1/config.h, mptests/mp01/node1/mp01_node1.adb, mptests/mp01/node2/config.h, mptests/mp01/node2/mp01_node2.adb, mptests/mp02/config_base.h, mptests/mp02/node1/config.h, mptests/mp02/node1/mp02_node1.adb, mptests/mp02/node2/config.h, mptests/mp02/node2/mp02_node2.adb, mptests/mp03/config_base.h, mptests/mp03/node1/config.h, mptests/mp03/node1/mp03_node1.adb, mptests/mp03/node2/config.h, mptests/mp03/node2/mp03_node2.adb, mptests/mp04/config_base.h, mptests/mp04/node1/config.h, mptests/mp04/node1/mp04_node1.adb, mptests/mp04/node2/config.h, mptests/mp04/node2/mp04_node2.adb, mptests/mp05/config_base.h, mptests/mp05/node1/config.h, mptests/mp05/node1/mp05_node1.adb, mptests/mp05/node2/config.h, mptests/mp05/node2/mp05_node2.adb, mptests/mp06/config_base.h, mptests/mp06/node1/config.h, mptests/mp06/node1/mp06_node1.adb, mptests/mp06/node2/config.h, mptests/mp06/node2/mp06_node2.adb, mptests/mp07/config_base.h, mptests/mp07/node1/config.h, mptests/mp07/node1/mp07_node1.adb, mptests/mp07/node2/config.h, mptests/mp07/node2/mp07_node2.adb, mptests/mp08/config_base.h, mptests/mp08/node1/config.h, mptests/mp08/node1/mp08_node1.adb, mptests/mp08/node2/config.h, mptests/mp08/node2/mp08_node2.adb, mptests/mp09/config_base.h, mptests/mp09/node1/config.h, mptests/mp09/node1/mp09_node1.adb, mptests/mp09/node2/config.h, mptests/mp09/node2/mp09_node2.adb, mptests/mp10/config_base.h, mptests/mp10/node1/config.h, mptests/mp10/node1/mp10_node1.adb, mptests/mp10/node2/config.h, mptests/mp10/node2/mp10_node2.adb, mptests/mp11/config_base.h, mptests/mp11/node1/config.h, mptests/mp11/node1/mp11_node1.adb, mptests/mp11/node2/config.h, mptests/mp11/node2/mp11_node2.adb, mptests/mp12/config_base.h, mptests/mp12/node1/config.h, mptests/mp12/node1/mp12_node1.adb, mptests/mp12/node2/config.h, mptests/mp12/node2/mp12_node2.adb, mptests/mp13/config_base.h, mptests/mp13/node1/config.h, mptests/mp13/node1/mp13_node1.adb, mptests/mp13/node2/config.h, mptests/mp13/node2/mp13_node2.adb, mptests/mp14/config_base.h, mptests/mp14/node1/config.h, mptests/mp14/node1/mp14_node1.adb, mptests/mp14/node2/config.h, mptests/mp14/node2/mp14_node2.adb: New files. GNATMAKE is easier to operate if the filename of the main package matches the executable name. In this case, we needed one for each node's executable. * mptests/mp01/config.h: Removed.
