path: root/c/src/ada-tests/mptests/mp08/Makefile.am (follow)
* ada-tests: Move to testsuites/adaSebastian Huber2017-10-121-4/+0
| | | | | | | This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079.
* ada-tests: Use _SUBDIRS instead of SUBDIRSSebastian Huber2017-10-121-1/+1
| | | | Update #3079.
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+2
* Remove CVS-Ids.Ralf Corsépius2012-05-041-2/+0
* New.Ralf Corsepius2005-11-201-0/+6
