* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to reorganize | Joel Sherrill | 1999-04-19 | 1 | -286/+0 |
| | | | | | | | | | | | the build-tools layout to simplify it. This script reorganizes and simpilfies the build-tools subdirectories. It moves all source-files and scripts to c/build-tools/. This will enable use to use this directory directly to refer to the build-tools instead of copying them around in a "preinstall" step in future. However, RTEMS's autoconf Makefile.ins and *.cfg files are not yet prepared to apply this approach and therefore require additional work. | ||||
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 1 | -0/+3 |
* | Added | Joel Sherrill | 1995-09-11 | 1 | -0/+283 |
