* | bsp/atsam: Do not disable the WDT | Sebastian Huber | 2019-06-13 | 2 | -4/+0 | |
| | | | | | The watchdog timer (WDT) can be configure only once. Do not touch it in the BSP since the application may want to use it. | |||||
* | bsp/atsam: Improve RTC power driver | Sebastian Huber | 2019-06-13 | 2 | -10/+25 | |
| | | | | Accept a time interval up to 24h. | |||||
* | bsp/atsam: Fix RTC_SetTimeAlarm() | Sebastian Huber | 2019-06-12 | 1 | -7/+13 | |
| | | | | Set the alarm time according to the note in the datasheet. | |||||
* | bsp/lpc24xx: Fix LPC24XX_IO_PORT_COUNT | Sebastian Huber | 2019-06-04 | 1 | -1/+5 | |
* | bsps/powerpc: Adjust ppcboot.lds | Sebastian Huber | 2019-05-27 | 1 | -10/+14 | |
| | | | | | | | | | | | | | | | | The GNU ld had a couple of changes which resulted in a broken bootloader image generation. Recent linker versions tie assignments to their nearest output section statement. Place all absolute symbols which are used with @sectoff relocations into a special section. See also: "Binutils 2.28 on PowerPC: dangerous relocation: generic linker can't handle R_PPC_SECTOFF_HA" https://www.sourceware.org/ml/binutils/2019-05/msg00183.html Update #3727 | |||||
* | bsps: Fix warnings in greth | Sebastian Huber | 2019-05-27 | 2 | -7/+7 | |
* | score: Remove SMP_MESSAGE_CLOCK_TICK | Sebastian Huber | 2019-05-20 | 2 | -11/+10 | |
| | | | | Use _SMP_Multicast_action() instead. | |||||
* | score: Simplify _SMP_Multicast_action() | Sebastian Huber | 2019-05-20 | 1 | -2/+23 | |
| | | | | | | Move resposibility to disable thread dispatching to the caller of _SMP_Multicast_action(). Using an interrupt disable for this purpose is questionable. | |||||
* | score: Add _SMP_Othercast_action() | Sebastian Huber | 2019-05-20 | 2 | -13/+9 | |
* | score: Add _SMP_Broadcast_action() | Sebastian Huber | 2019-05-20 | 3 | -4/+4 | |
* | bsps: Always build generic interrupt support | Sebastian Huber | 2019-05-16 | 41 | -0/+164 | |
| | | | | | | | This makes it possible to write tests for the generic interrupt controller support. Update #3269. | |||||
* | bsps/arm: Adjust machine flags for ARMv7-M | Sebastian Huber | 2019-05-14 | 6 | -6/+15 | |
| | | | | | | | Update machine flags for Cortex-M3 and Cortex-M4 based BSPs to account for Cortex-M3 Errata 602117 which required GCC multilib changes. Update #3747. | |||||
* | Removed entry from Related Pages | Andreas Dachsberger | 2019-05-13 | 1 | -0/+2 | |
| | | | | | SAM V71 Xplained Ultra - Board explanation now in Modules->BSPs->ARM Update #3706. | |||||
* | bsp/lpc24xx: Fix dynamic EMC configurations | Sebastian Huber | 2019-05-09 | 1 | -2/+5 | |
* | bsp/lpc24xx: Use fast slew rate for EMC pins | Sebastian Huber | 2019-05-09 | 1 | -84/+63 | |
* | bsp/lpc24xx: Add LPC17XX_PIN_TYPE_FAST_SLEW_RATE | Sebastian Huber | 2019-05-09 | 2 | -1/+5 | |
* | bsp/lpc24xx: Add SDRAM mode settings comment | Sebastian Huber | 2019-05-09 | 1 | -1/+10 | |
* | bsp/lpc24xx: Fix LPC24XX_EMC_MT48LC4M16A2 MPU cfg | Sebastian Huber | 2019-05-08 | 1 | -7/+8 | |
* | bsp/lpc24xx: Flexible LPC24XX_EMC_MT48LC4M16A2 cfg | Sebastian Huber | 2019-05-08 | 1 | -17/+24 | |
* | bsp/lpc24xx: LPC24XX_EMC_MT48LC4M16A2 MPU support | Sebastian Huber | 2019-05-08 | 1 | -2/+6 | |
* | bsp/lpc24xx: Support LPC24XX_EMC_SST39VF3201 pins | Sebastian Huber | 2019-05-08 | 1 | -3/+7 | |
* | bsps/powerpc: Fix constructors with priority | Sebastian Huber | 2019-05-07 | 1 | -19/+8 | |
| | | | | Update #3339. | |||||
* | bsps/powerpc: Fix C++ exception handling | Sebastian Huber | 2019-05-07 | 1 | -2/+3 | |
| | | | | Close #3736. | |||||
* | bsp/motorola_powerpc: Fix bootloader output | Sebastian Huber | 2019-05-07 | 1 | -0/+4 | |
* | bsps: Remove bogus config declaration | Sebastian Huber | 2019-05-06 | 3 | -3/+3 | |
| | | | | | | | Replace it with a proper struct rtems_bsdnet_ifconfig forward declaration. Close #3742. | |||||
* | bsp/motorola_powerpc: Fix debug output | Sebastian Huber | 2019-04-12 | 2 | -4/+4 | |
| | | | | Update #3122. | |||||
* | score: Remove _SMP_Before_multitasking_action() | Sebastian Huber | 2019-04-12 | 2 | -16/+14 | |
* | score: Use processor mask in _SMP_Multicast_action | Sebastian Huber | 2019-04-12 | 1 | -2/+2 | |
| | | | | Processor_mask is the internal data type to deal with processor sets. | |||||
* | score: Rename _SMP_Get_processor_count() | Sebastian Huber | 2019-04-11 | 3 | -12/+14 | |
| | | | | | | | Rename _SMP_Get_processor_count() in _SMP_Get_processor_maximum() to be in line with the API level rtems_scheduler_get_processor_maximum(). Update #3732. | |||||
* | score: Rename _SMP_Processor_count | Sebastian Huber | 2019-04-11 | 1 | -1/+1 | |
| | | | | | | | Rename _SMP_Processor_count in _SMP_Processor_maximum to be in line with the API level rtems_scheduler_get_processor_maximum(). Update #3732. | |||||
* | bsp/xilinx-zynqmp: Implement Ultra96 target | Jeff Kubascik | 2019-04-11 | 14 | -162/+208 | |
| | | | | | | Modifications to get xilinx-zynqmp BSP working on an Ultra96 board. Update #3682. | |||||
* | bsp/xilinx-zynqmp: Stub out Xilinx MPSoC BSP | Jeff Kubascik | 2019-04-11 | 14 | -0/+738 | |
| | | | | | | Source files were copied from xilinx-zynq. Update #3682. | |||||
* | bsp/zynq-uart: Move Zynq UART driver to shared directory | Jeff Kubascik | 2019-04-11 | 5 | -2/+2 | |
| | | | | | | This driver will be shared with the xilinx-zynqmp BSP. Update #3682. | |||||
* | bsp/zynq-uart: Remove zynq_uart_instances from header | Jeff Kubascik | 2019-04-11 | 3 | -3/+5 | |
| | | | | | | | This variable is BSP specific and should be removed from the driver header file. Update #3682. | |||||
* | bsp/xilinx-zynq: Relicense to BSD-2-Clause | Sebastian Huber | 2019-04-10 | 17 | -153/+374 | |
| | | | | | | | | Relicense contributions from Chris Johns, Christian Mauderer, embedded brains GmbH, Joel Sherrill, OAR, Pavel Pisa, Ralf Kirchner, and Sebastian Huber. Update #3053. | |||||
* | rtems: Add rtems_scheduler_get_processor_maximum() | Sebastian Huber | 2019-04-09 | 6 | -9/+9 | |
| | | | | | | | | | | | Add rtems_scheduler_get_processor_maximum() as a replacement for rtems_get_processor_count(). The rtems_get_processor_count() is a bit orphaned. Adopt it by the Scheduler Manager. The count is also misleading, since the processor set may have gaps and the actual count of online processors may be less than the value returned by rtems_get_processor_count(). Update #3732. | |||||
* | rtems: Add rtems_scheduler_get_processor() | Sebastian Huber | 2019-04-09 | 2 | -2/+2 | |
| | | | | | | | | | | | Add rtems_scheduler_get_processor() as a replacement for rtems_get_current_processor(). The rtems_get_current_processor() is a bit orphaned. Adopt it by the Scheduler Manager. This is in line with the glibc sched_getcpu() function. Deprecate rtems_get_current_processor(). Update #3731. | |||||
* | bsps/arm: Optimize ARMv7-M CPU counter | Sebastian Huber | 2019-04-09 | 1 | -4/+5 | |
| | | | | Update #3456. | |||||
* | bsps/arm: Fix ARMv7-M CPU counter | Sebastian Huber | 2019-04-09 | 1 | -0/+1 | |
| | | | | | | | Read the current counter value again after we know that we had an underflow. Update #3456. | |||||
* | doxygen: Added subgroup Generic to BSP->SPARC64 | Andreas Dachsberger | 2019-04-04 | 4 | -3/+11 | |
* | Set the small data section size to max. for beatnik BSPs. | Goetz Pfeiffer | 2019-04-04 | 1 | -0/+2 | |
| | | | | | This applies changes similar to patch 294c6f46a6 to the beatnik BSP. This is a board support for the mvme5500 and mvme6100 CPU. | |||||
* | doxygen: bsps: Added remaining Sparc64 groups | Andreas Dachsberger | 2019-04-02 | 17 | -16/+23 | |
* | Set the small data section size to max. for mvme5500 and mvme2100 BSPs | Chris Johns | 2019-03-30 | 2 | -0/+4 | |
| | | | | Closes #3728 | |||||
* | erc32/start/setvec.c: Fix warning | Joel Sherrill | 2019-03-25 | 1 | -3/+8 | |
* | bsp/atsam: Fix SPI driver DMA support | Sebastian Huber | 2019-03-19 | 1 | -144/+154 | |
* | bsp/atsam: Simplify XDMAD_Handler() | Sebastian Huber | 2019-03-19 | 2 | -56/+7 | |
| | | | | | Remove the channel status evaluation from XDMAD_Handler() and simply hand over the status to the callbacks. | |||||
* | bsp/lpc24xx: Convert I2C driver to Linux API | Sebastian Huber | 2019-03-15 | 3 | -364/+435 | |
| | | | | | | Change license to BSD-2-Clause. Close #3725. | |||||
* | bsps/powerpc: Initialize stack earlier | Sebastian Huber | 2019-03-15 | 1 | -9/+9 | |
| | | | | | | The __eabi() call may use the stack. Update #3459. | |||||
* | z85c30.c: Do not process 0 baud and return an error (CID 1399713) | Joel Sherrill | 2019-03-14 | 1 | -0/+9 | |
* | Remove superfluous <rtems/system.h> includes | Sebastian Huber | 2019-03-14 | 21 | -24/+1 | |
