path: root/bsps/riscv (follow)
* bsps: Support RTEMS_NOINIT in linkcmdsSebastian Huber2021-05-022-0/+11
| | | | Update #3866.
* bsps: Remove networking driversVijay Kumar Banerjee2021-04-071-59/+0
| | | | Update #3850
* bsps/riscv: Add per cpu clock interruptJan Sommer2021-03-231-10/+49
| | | | - Fixes failure of test smpclock01
* bsp/riscv: Re-license to BSD-2-ClauseSebastian Huber2021-02-091-10/+37
| | | | | | Change license to BSD-2-Clause according to file history. Update #3053.
* bsps: Replace bsp_specs with an empty fileSebastian Huber2021-01-282-18/+0
| | | | | | | This fixes an issue with the latest tool chain which adds the default linker script in the endfile specification. Update #3250.
* bsps: Add missing DWARF 5 sectionsSebastian Huber2021-01-261-3/+5
| | | | Sort alphabetically.
* bsps: Support DWARF 5 sectionsSebastian Huber2021-01-251-20/+30
| | | | GCC 11 uses DWARF 5 by default.
* Add networking support for griscv bspJiri Gaisler2020-11-093-1/+74
| | | | | | | * Only GRETH device supported for now * Fix endian problem in GRETH driver * Remove SPARC assembly from greth.c * Builds with both autoconf and waf
* grlib: Add and use irqmp_has_timestamp()Sebastian Huber2020-10-101-1/+1
| | | | | | | Replace leon3_irqmp_has_timestamp() with irqmp_has_timestamp() and move it to grlib.h. Close #4128.
* bsps/riscv: Add bsp_fdt_map_intr()Sebastian Huber2020-09-231-0/+6
| | | | This function is required by libbsd.
* riscv: Make sifive_test finisher 4 bytesHesham Almatary2020-09-171-1/+1
| | | | | | QEMU is now stricter with MMIO sizes and accesses. uintptr_t on RV64 is 8 bytes and generates an sd instruction that Store/AMO faults because sifive_test MMIO expects 4 bytes accesses.
* bsps/riscv: Use far jump to boot_card()Sebastian Huber2020-09-151-1/+1
| | | | | | Use a far jump to avoid errors like this: relocation truncated to fit: R_RISCV_JAL against symbol `boot_card'
* htif_console_handler is defined in htif.cHesham Almatary2020-09-061-1/+1
| | | | closes #4069.
* bsps: Always install IPI in SMP configsSebastian Huber2020-08-311-12/+9
| | | | | | | The inter-processor interrupt (IPI) may be used to process per-CPU jobs. See for example the blocked handler in T_interrupt_test(). Update #3199.
* bsps/riscv: Fix multiple definitionSebastian Huber2020-04-101-2/+0
* imfs: Replace devfs with an IMFS specializationSebastian Huber2020-03-091-3/+0
| | | | | | | | | | | | | | | | Add a simplified path evaluation function IMFS_eval_path_devfs() for a device only IMFS configuration. The code size can be further reduced by the application if it disables the support for legacy IO drivers via: #define CONFIGURE_IMFS_DISABLE_MKNOD #define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE Obsolete CONFIGURE_MAXIMUM_DEVICES. Remove BSP_MAXIMUM_DEVICES. Update #3894. Update #3898.
* Use RTEMS_SYSINIT_ORDER_LAST_BUT_5Sebastian Huber2020-02-041-1/+1
| | | | | | | | Use RTEMS_SYSINIT_ORDER_LAST_BUT_5 instead of RTEMS_SYSINIT_ORDER_LAST to allow applications and support functions to place system initialization handlers behind the standard handlers. Update #3838.
* bsps: Add RamEnd to linker command filesSebastian Huber2020-02-041-0/+1
| | | | Update #3838.
* Regenerate headers.amSebastian Huber2019-11-291-0/+1
* bsp/riscv: Fix format and warningsSebastian Huber2019-11-142-45/+27
| | | | Update #3785.
* bsp/riscv: Fix use of uninitialized integerSebastian Huber2019-11-141-6/+1
* bsp/riscv: riscv_get_core_frequency()Sebastian Huber2019-11-142-43/+23
| | | | | | | Always provide this function. Return 0 by default. Fix formatting. Simplify function. Update #3785.
* bsps/riscv: UART - Read reg-shift from DTB to properly set/get registersHesham Almatary2019-10-301-2/+13
* riscv: Add new BSP cfg variants to be built with llvm/clangHesham Almatary2019-10-278-0/+112
* riscv: Add new offending input sections to the linker scriptHesham Almatary2019-10-271-0/+5
* riscv: Add NOLOAD directive to the .work sectionHesham Almatary2019-10-271-1/+1
| | | | ld.lld defaults .work to PROGBITS otherwise
* riscv: Address differences in the linkerscript between GNU LD and LLVM/LLDHesham Almatary2019-10-271-51/+51
| | | | | | | | | | LLVM/LLD does not support STARTUP and ALIGN_WITH_INPUT directives that GNU LD support. INPUT and ALIGN(8) are supported by LLVM/LLD and can replace the unsupported STARTUP/ALIGN_WITH_INPUT directives. The commit conditionally adds the supported directive that linkers can understand depending on the toolchain used to compile RTEMS i.e., clang or gcc. Clang is assumed to use LLD by default.
* riscv: Generate linkcmds.base from the shared linkcmds.base.inHesham Almatary2019-10-271-0/+0
| | | | | This commit moves the existing linkcmds.base to linkcmds.base.in in order to make it configurable by autotools.
* riscv: add freedom E310 Arty A7 bspPragnesh Patel2019-10-237-5/+312
| | | | | | | Added support for Sifive Freedom FE310 soc on Arty A7 FPGA board. Update #3785. Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com>
* score: Rename _SMP_Get_processor_count()Sebastian Huber2019-04-111-9/+9
| | | | | | | Rename _SMP_Get_processor_count() in _SMP_Get_processor_maximum() to be in line with the API level rtems_scheduler_get_processor_maximum(). Update #3732.
* rtems: Add rtems_scheduler_get_processor_maximum()Sebastian Huber2019-04-092-3/+3
| | | | | | | | | | | Add rtems_scheduler_get_processor_maximum() as a replacement for rtems_get_processor_count(). The rtems_get_processor_count() is a bit orphaned. Adopt it by the Scheduler Manager. The count is also misleading, since the processor set may have gaps and the actual count of online processors may be less than the value returned by rtems_get_processor_count(). Update #3732.
* bsps: Adjust shared Doxygen groupsSebastian Huber2019-03-082-2/+10
| | | | Update #3706.
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-083-3/+57
| | | | Update #3706.
* bsps: Adjust architecture Doxygen groupsSebastian Huber2019-03-041-0/+7
| | | | | | | | | | - Use CamelCase as it is not used in our C code. Enables simple search and replace. - Prefix with "RTEMS" to aid deployment and integration. It aids searching and sorting. Update #3706.
* griscv: add additional cpu configurationsJiri Gaisler2019-02-085-1/+37
| | | | | * Also switch default config to imafd as the C extension is not supported for code coverage
* riscv: add griscv bspJiri Gaisler2019-01-2219-0/+1315
| | | | Update #3678.
* bsp/riscv: Clear boot command lineSebastian Huber2019-01-081-0/+1
* score: Rename interrupt stack symbolsSebastian Huber2018-11-081-3/+3
| | | | | | | | | | | | | Rename * _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin, * _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and * _Configuration_Interrupt_stack_size in _ISR_Stack_size. Move definitions to <rtems/score/isr.h>. The new names are considerable shorter and in the right namespace. Update #3459.
* riscv: Allow platforms with no PLIC to proceedHesham Almatary2018-09-171-0/+5
| | | | Spike simulator and QEMU's spike_v1.10 don't have a PLIC
* bsp/riscv: Add missing BSP variantSebastian Huber2018-08-021-0/+9
| | | | Update #3433.
* bsp/riscv: Fix build with RTEMS_SMP undefinedSebastian Huber2018-08-023-12/+10
| | | | Update #3433.
* bsp/riscv: Fix a synchronization issue for PLICSebastian Huber2018-08-021-0/+8
| | | | Update #3433.
* bsp/riscv: Remove unused variableSebastian Huber2018-08-011-4/+0
| | | | Update #3433.
* bsp/riscv: Add NS16750 support to console driverSebastian Huber2018-08-011-36/+74
| | | | Update #3433.
* bsp/riscv: Initialize FPU depending on ISASebastian Huber2018-08-011-1/+4
| | | | | | Initialize fcsr to zero for a defined rounding mode. Update #3433.
* bsp/riscv: Fix clock driverSebastian Huber2018-08-011-17/+49
| | | | | | Do not assume that mtime is zero at boot time. Update #3433.
* bsp/riscv: Fix inter-processor interruptsSebastian Huber2018-07-271-1/+7
| | | | | | | | The previous version worked only on a patched Qemu. Writes to mip are illegal according to the The RISC-V Instruction Set Manual, Volume II: Privileged Architecture, Privileged Architecture Version 1.10. Update #3433.
* riscv: Rework CPU counter supportSebastian Huber2018-07-271-4/+18
| | | | Update #3433.
* bsp/riscv: Use interrupt driven NS16550 driverSebastian Huber2018-07-251-1/+9
| | | | Update #3433.
* bsp/riscv: Add PLIC supportSebastian Huber2018-07-254-2/+258
| | | | Update #3433.
