Note: The changes have been done with portability in mind. The driver
should (in theory) be able to replace the original one in the MPC BSPs
too. For full compatibility an adaption layer and especially a test
would be necessary. Because both are missing, don't integrate it into
the MPC BSP now.
Update #4180
This is a preparation for making the driver universal.
Update #4180
RTEMS OFW is a FDT only implementation of the OpenFirmWare
interface. This API is created to be compatible with FreeBSD
OpenFirmWare interface. The main intention is to make
porting of FreeBSD drivers to RTEMS easier.
Most functions implemented have an direct one-one mapping
with the original OFW API and some extra auxiliary functions
were implemented to make working with device trees easier in
RTEMS.
Update #3784
This avoids a function call overhead in the interrupt dispatching.
Update #4202.
Avoid one level of indirection.
Update #4202.
Update #4202.
The arm_cp15 function for accessing the current CPU index is specific
to ARMv7 while this header is used for ARMv8 as well. Instead, use a
generic accessor that is part of the standard CPU API.
Remove the target filter for software-generated interrupts since this
feature is not supported by the affinity routing in GICv3.
Update #4202.
Use the targets parameter to determine the targets of the SGI. Change
targets parameter type to 32-bit to ease the parameter passing. GICv3
supports up to 16 targets.
Update #4202.
Currently, zynq-uart code is always built and has some requirements for
BSPs that use it. Instead of making all BSPs satisfy that requirement or
working around it by setting defaults, this moves the zynq-uart code
into its own spec build object so it can be included if needed.
The zynq-uart set_attributes implementation was configured to always
return false which causes spconsole01 to fail. This restores the
disabled implementation which sets the baud rate registers
appropriately and allows spconsole01 to pass. This also expands the
set_attributes functionality to allow setting of the stop bits,
character width, and parity.
This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64
code.
This moves the zynq-uart driver from bsps/arm/shared to bsps/shared to
accomodate use by AArch64 BSPs.
Update #4180
This avoids a cast in DEV_TO_COMMON().
Provide RTEMS_NO_RETURN also in case RTEMS_DEBUG is defined to prevent errors
like this:
error: no return statement in function returning non-void [-Werror=return-type]
Use C11 and C++11 standard means to declare a no-return function.
Close #4122.
Replace leon3_irqmp_has_timestamp() with irqmp_has_timestamp() and move
it to grlib.h.
Close #4128.
updates #4028.
This breaks out AArch32-specific code so that the shared GICv3 code can
be reused by other architectures.
This breaks AArch32-specific portions of the ARM GPT driver into their
own file so that the generic code can be moved for reuse by other
architectures.
This UART driver is now needed for BSPs other than ARM.
Update 3869
This patch will allow the user to pass a function to calculate
the baud divisor.
This will allow for more flexibility, since for some BSPs
like raspberrypi, the calculation of baud divisor is different
from what is in the current driver.
The work area initialization was done by the BSP through
bsp_work_area_initialize(). This approach predated the system
initialization through the system initialization linker set. The
workspace and C program heap were unconditionally initialized. The aim
is to support RTEMS application configurations which do not need the
workspace and C program heap. In these configurations, the workspace
and C prgram heap should not get initialized.
Change all bsp_work_area_initialize() to implement _Memory_Get()
instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and
malloc() heap initialization into separate system initialization steps.
This makes it also easier to test the individual initialization steps.
This change adds a dependency to _Heap_Extend() to all BSPs. This
dependency will be removed in a follow up change.
Update #3838.
The code covered by BSP_GET_WORK_AREA_DEBUG was basically dead code
since there was no normal way to activate it (e.g. via a BSP
configuration option). A follow up patch will bring back this feature
through a CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION configuration option.
Update #3838.
Replace the user MPCI configuration table with a system provided
_MPCI_Configuration.
Update #3735.
Update #3841.
Use watchdog for shared memory driver instead of a Classic API Timer.
Added support for Sifive Freedom FE310 soc on Arty A7 FPGA board.
Update #3785.
Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com>
controller support.
Update #3269.
Update #3706.
Update #3706.
Update #3706.
They are only used by PowerPC BSPs.
replace.
searching and sorting.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
Update #3678.
Update #3678.
Update #3678.
Update #3678.
Drop unused and deprecated functions from the ATA_DRIVER_TABLE_ENTRY.
Update #3358.
Close #3510.
Update #3358.
Set the FIFO control register while DLAB == 1 in the line control
register. At least on the QorIQ T4240 the driver still works with the
re-ordered FIFO control register access.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
