This allows applications to individually provide configuration
structures.
Update #4209.
structures.
Update #4209.
This BSP supports the Arm Fixed Virtual Platform. Only the Cortex-R52
processor configuration is supported by the BSP. It should be easy to
add support for other variants if needed.
Update #4202.
The arm_cp15_set_exception_handler() is a complicated function which
should be avoided if possible.
Update #4202.
This avoids a function call overhead in the interrupt dispatching.
Update #4202.
Update #4202.
Initialize the data and unified cache levels. Invalidate the
instruction cache levels.
Update #4202.
This makes it possible to reuse this loop.
Update #4202.
The start hook arguments are not used by a BSP. Removing them avoids
the need for a stack during the very early system initialization.
Update #4202.
Make sure the branch predictors are invalidated before the first branch
is executed.
Update #4202.
Set the VBAR to the vector table in the start section before
bsp_start_hook_0() is called to earlier handle exceptions in RTEMS.
Set the VBAR to the normal vector table in start.S for the main
processor. Secondary processors set it in bsp_start_hook_0().
Update #4202.
Avoid one level of indirection.
Update #4202.
Update #4184.
When moving the headers from the imx BSP to the shared area, the wrong
directory has been selected. This patch fixes that problem.
Update #4180
This allows simpler creation of own dts files for custom boards.
Update #4180
- For small tables only round to the next 4kiB instead of 1MiB
Close #4184.
Remove the target filter for software-generated interrupts since this
feature is not supported by the affinity routing in GICv3.
Update #4202.
Use the targets parameter to determine the targets of the SGI. Change
targets parameter type to 32-bit to ease the parameter passing. GICv3
supports up to 16 targets.
Update #4202.
Update #4202.
This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64
code.
This moves the zynq-uart driver from bsps/arm/shared to bsps/shared to
accomodate use by AArch64 BSPs.
Update #3910.
Update #4180
Update #4180
Update #4180
The following files have been imported:
cp ${SDK}/boards/evkbimxrt1050/project_template/clock_config.c nxp/boards/evkbimxrt1050
cp ${SDK}/boards/evkbimxrt1050/project_template/clock_config.h include/fsl_clock_config.h
cp ${SDK}/boards/evkbimxrt1050/project_template/dcd.c start/flash-dcd.c
cp ${SDK}/boards/evkbimxrt1050/project_template/pin_mux.c nxp/boards/evkbimxrt1050
cp ${SDK}/boards/evkbimxrt1050/project_template/pin_mux.h include/fsl_pin_mux.h
cp ${SDK}/boards/evkbimxrt1050/xip/evkbimxrt1050_flexspi_nor_config.h include/fsl_flexspi_nor_config.h
cp ${SDK}/devices/MIMXRT1052/MIMXRT1052.h include
cp ${SDK}/devices/MIMXRT1052/MIMXRT1052_features.h include
cp ${SDK}/devices/MIMXRT1052/drivers/fsl_*.c nxp/devices/MIMXRT1052/drivers
cp ${SDK}/devices/MIMXRT1052/drivers/fsl_*.h include
cp ${SDK}/devices/MIMXRT1052/fsl_device_registers.h include
cp ${SDK}/devices/MIMXRT1052/system_MIMXRT1052.h include/
cp ${SDK}/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.c nxp/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.c
cp ${SDK}/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.h include
Update #4180
Modify the MPU functions of the stm32h7 BSP to be table based and
available for all ARMV7M BSPs.
Update #4180
Update #4180
Update #4180
In "bsp/atsam: Simplify XDMAD_Handler()" (5f813694f68cee) the interrupt
callback has been made unconditional. That allowed to avoid some special
deadlock situations in error cases. But it removed part of the XDMAD
status handling.
This patch adds the ability to update the XDMAD status from the
callback if that is necessary for the driver.
Fixes #4173
Update #3910.
Update #3910.
Update #3910.
Update #3910.
This is necessary for libbsd compatibility.
Update #3910.
Update #3910.
Update #3910.
Update #3910.
Add a workaround for Cortex-A9 Errata 845369: A short loop including a DMB
instruction might cause a denial of service on another which executes a CP15
broadcast operation.
Close #4115.
Add a workaround for Cortex-A9 Errata 845369: Under Very Rare Timing
Circumstances Transition into Streaming Mode Might Create Data Corruption.
Update #4115.
