Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector
numbers start with zero.
The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit
and building all BSPs.
Update #3269.
This fixes an issue with the latest tool chain which adds the default
linker script in the endfile specification.
Update #3250.
Updates #3938.
Updates #3938.
Update #3938.
Update machine flags for Cortex-M3 and Cortex-M4 based BSPs to account
for Cortex-M3 Errata 602117 which required GCC multilib changes.
Update #3747.
Change license to BSD-2-Clause.
Close #3725.
BSP small memory
small memory
Use interrupts instead of polled or DMA driven mode. Change license to
BSD-2-Clause.
Close #3724.
Update #3706.
replace.
searching and sorting.
Update #3706.
Close #3502.
Add rtems_counter_frequency() API function. Use it to initialize the
counter value converter via the new system initialization step
(RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation
and the counter converter. It avoids an unnecessary pull in of the
64-bit integer division from libgcc.
Update #3456.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
