Add addresses and interrupts for most internal peripherals to the dts.
The additional aliases make it possible for an application to easily
access these informations.
Update #4180
Remove symbols that would be necessary for overlays and decrease padding
that would be necessary for adding stuff during run-time.
Update #4180
Makes it simpler to access the QTMR in an application via a FDT name or
link in an application specific FDT entry.
Also currently no driver uses these numbers, it is usefull for
applications that want to use the DMA.
Update #4180
If spi or i2c slaves are "connected" to the spi or i2c bus, the device
tree compiler complains if the busses are not named spi or i2c.
Update #4180
This allows simpler creation of own dts files for custom boards.
Update #4180
Update #4180
