The pinctrl-0 of the video_mux might overwrite pin settings done by
other peripherals. Disabling it by default prevents unexpected pin
settings.
Enable the USB modules in the FDT.
The BSP is for a custom i.MXRT1166 based board. At the moment, only the
cortex M7 is supported.
brains GmbH.
A device tree binary has to be 8 byte aligned in memory. This is checked
since RTEMS commit 34052ef78cf8724dee73e9279b2c6bff8cfed234 "libfdt: Add
FDT alignment check to fdt_check_header()".
Add addresses and interrupts for most internal peripherals to the dts.
The additional aliases make it possible for an application to easily
access these informations.
Update #4180
Remove symbols that would be necessary for overlays and decrease padding
that would be necessary for adding stuff during run-time.
Update #4180
Makes it simpler to access the QTMR in an application via a FDT name or
link in an application specific FDT entry.
Also currently no driver uses these numbers, it is usefull for
applications that want to use the DMA.
Update #4180
If spi or i2c slaves are "connected" to the spi or i2c bus, the device
tree compiler complains if the busses are not named spi or i2c.
Update #4180
This allows simpler creation of own dts files for custom boards.
Update #4180
Update #4180
