path: root/aclocal/check-makefile.m4 (follow)
* Obsolete files. Removed per recommendation from Ralf CorsepiusJoel Sherrill2000-02-041-12/+0
| | | | <corsepiu@faw.uni-ulm.de>.
* Added Id's.Joel Sherrill1998-09-301-0/+2
* Update from Ralf Corsepius:Joel Sherrill1998-02-171-2/+1
| | | | | | | 6) The macro files from aclocal/*.m4 contain the buggy sed-rules formerly contained in aclocal..m4, i.e. the sed/sort-bug fix to aclocal.m4 didn't make it to aclocal/*.m4. I think I should feel guilty for that - Obviously I submitted the contents of an old aclocal-directory last time. - Sorry.
* New autoconf feature from Ralf Corsepius:Joel Sherrill1998-02-041-0/+11
It adds make rules for reconfiguring build-trees ("make Makefile") and adds dependency rules for configure and friends (i.e. calls autoconf). Most of this code has been "borrowed" from automake and was adapted to rtems. Addionally, I added automatic generation of the "aclocal.m4"-file by "aclocal" (from the automake package). Therefore I splitted aclocal.m4 into several separate files (attached to this mail), each containing one of rtems customized autoconf/m4-macros and have put them into a new subdirectory "aclocal". Normal users won't be influenced and won't even need this, unless they try to modify configure.in. The main advantage of this is: these aclocal/m4-macros become reusable and easier to administer. As a disadvantage, rtems becomes dependent of having aclocal/automake installed. To keep building rtems functional if autoconf or aclocal isn't installed, the related Makefile commands are prefixed by "-" -- only an error message should be issued by "make".
