* aclocal/bsp-arg-enable.m4, aclocal/bsp-configure.m4,
aclocal/bspopts.m4, aclocal/canonicalize-tools.m4,
aclocal/check-bsp-cache.m4, aclocal/check-cxx.m4,
aclocal/check-itron.m4, aclocal/check-multiprocessing.m4,
aclocal/check-networking.m4, aclocal/check-newlib.m4,
aclocal/check-posix.m4, aclocal/check-rdbg.m4,
aclocal/check-tool.m4, aclocal/env-rtemsbsp.m4,
aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4,
aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4,
aclocal/path-perl.m4, aclocal/ppc.m4,
aclocal/prog-cc.m4, aclocal/prog-ccas.m4,
aclocal/prog-cxx.m4, aclocal/prog-gnat.m4,
aclocal/rtems-debug.m4, aclocal/rtems-flags.m4,
aclocal/rtems-test-no-pause.m4, aclocal/target.m4:
Remove (Unused).
* automake/leaf.am, automake/force-preinstall.am:
Remove (Unused).
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that is a somewhat experimental, multilib-related patch:
* Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in
configure.ins below exec/.
At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change
to emphasize that these subdirectories shall not depend on RTEMS_BSP
than a real behavioral change.
* Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare
autoheader/autoconf generated targopts.h and similiar configuration
headers.
* c/src/configure.in: remove exec from cfg_subdirs if multilibs are
enabled (c/src is build per bsp, exec shall be build per cpu in c/
or from the toplevel in future, when multilibs are enabled.)
* This patch should not have any impact on the current building scheme.
* --enable-multilib still does not work.
* running bootstrap from the toplevel directory is required.
CVS:
CVS: Committing in .
CVS:
CVS: Modified Files:
