* | 2003-08-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-21 | 1 | -26/+0 |
| | | | | | | | | | | | | | | | | | | | | | * aclocal/bsp-arg-enable.m4, aclocal/bsp-configure.m4, aclocal/bspopts.m4, aclocal/canonicalize-tools.m4, aclocal/check-bsp-cache.m4, aclocal/check-cxx.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-newlib.m4, aclocal/check-posix.m4, aclocal/check-rdbg.m4, aclocal/check-tool.m4, aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4, aclocal/path-perl.m4, aclocal/ppc.m4, aclocal/prog-cc.m4, aclocal/prog-ccas.m4, aclocal/prog-cxx.m4, aclocal/prog-gnat.m4, aclocal/rtems-debug.m4, aclocal/rtems-flags.m4, aclocal/rtems-test-no-pause.m4, aclocal/target.m4: Remove (Unused). * automake/leaf.am, automake/force-preinstall.am: Remove (Unused). * Makefile.am: Reflect changes above. | ||||
* | 2003-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-05-16 | 1 | -1/+1 |
| | | | | | | * aclocal/check-cxx.m4: Remove LIBSUFFIX_VA. * automake/compile.am: Remove LIBSUFFIX_VA. Merger from rtems-4-6-branch. | ||||
* | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-02 | 1 | -1/+1 |
| | | | | | | | * aclocal/*: Replace with contents of macros/*.m4 * macros/: Remove. * aclocal/ar-s.m4 aclocal/tool-prefix.m4: Remove. * Makefile.am: Reflect changes to aclocal/ and macros/. | ||||
* | 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-12 | 1 | -0/+5 |
| | | | | | | | | * aclocal/check-cxx.m4: Add AC_SUBST(CPLUS_LD_LIBS) * aclocal/prog-cc.m4: Cleanup comments, require RTEMS_ENABLE_GCC28, add automake conditionals RTEMS_USE_GCC, RTEMS_USE_GCC272. * automake/compile.am: Replaced. * automake/local.am: Remove building variant handling. | ||||
* | Applied patch rtems-rc-19990820-6.diff.gz from | Joel Sherrill | 1999-09-07 | 1 | -0/+1 |
| | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> which converted many Makefile.in's to Makefile.am's. This added a lot of files. | ||||
* | New configuration files added by patch from | Joel Sherrill | 1999-08-10 | 1 | -0/+20 |
Ralf Corsepius <corsepiu@faw.uni-ulm.de>". |
