This support is required when newer firmware is used on
Raspberry Pi 2 boards.
When HYP mode is detected at startup then setup HYP mode
vectors table (for future extensions) clean exceptions
switching to HYP mode and switch CPU to ARM SVC mode.
BSPs which want to use this support need to include next option
in their configure.ac
RTEMS_BSPOPTS_SET([BSP_START_IN_HYP_SUPPORT],[*],[1])
RTEMS_BSPOPTS_HELP([BSP_START_IN_HYP_SUPPORT], [Support start of BSP in ARM HYP mode])
AM_CONDITIONAL(BSP_START_IN_HYP_SUPPORT,test "$BSP_START_IN_HYP_SUPPORT" = "1")
and need to include next lines in corresponding Makefile.am
if BSP_START_IN_HYP_SUPPORT
libbsp_a_SOURCES += ../shared/startup/bsp-start-in-hyp-support.S
endif
base access.
The main reason for inclusion of minimum hypervisor related defines
is that current ARM boards firmware and loaders (U-boot for example)
start loaded operating system kernel in HYP mode to allow it take
control of virtualization (Linux/KVM for example).
Some changes have been reverted to keep readability.
For example squash of BCM2835_MBOX_TAG_* defines
which are visually aligned in column.
This solution is quick fix until CPU_DATA_CACHE_ALIGNMENT is defined
and cache manager is checked on all Raspberry Pi variants.
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
clear of alt outputs.
TMS570LS3135ZWT chip.
synchronized through cache.
memory size.
The page table is placed at address 0x00004000 which provides
required 16 kB space till the start of application image.
The RAM size specified in a linker script is upper limit
address of RAM utilized for the work area initialization.
If VideoCore reports to use lower address than expected
then work area size is adjusted (shrinked) appropriately.
direct address.
raspberrypi.h
If the raspberrypi.h has been included without preceding inclussion
of bsp.h then BSP_IS_RPI2 has not been set for Raspberry Pi 2
BSP variant and bad things happen later.
The patch includes bspopts.h by raspberrypi.h and even includes
bsp.h in critical peripherals support.
cmdline argument is returned without option name.
The calls to command line parsing can be called earlier before
BSS is cleaned out.
This is required if function or direction is changed by some driver
after start of thread multitasking or in interrupts drivers.
There can be problem with calling GPIO function selection before
data section is initialized. But actual ticket lock implementation
seems to be compatible even with memory initialized to zero oven
on SMP.
Original implementation does only bitwise-or with previous register
value for all functions except IN. Switch from one to other function
would lead to incorrect value.
The current versions of U-boot start kernel/RTEMS application image
with instruction and data caches enabled and it sets exception
base register to new address after its self-relocation.
ldr r0, [r9, #GD_RELOCADDR] /* r0 = gd->relocaddr */
mcr p15, 0, r0, c12, c0, 0 /* Set VBAR */
Included changes in bsp_start_hook_0 restore default state to
allow RTEMS image to run after startup from newer U-boot version
on Raspberry Pi.
Clear interrupt enable registers in interrupt controller
to ensure that RTEMS starts from well defined state.
suppress GCC 6 warning.
closes #2634
The problem exists for both RTEMS untar implementations and their
variants: Untar_FromMemory(), Untar_FromFile() and rtems_tarfs_load().
If filesystem object already exists at extracted directory path
then if it is directory, creation is ignored. Attempt
to delete/unlink object and make directory is tried for other cases.
This simple approach problem reported in ticket fixes #2413.
Behavior follows GNU tar and BSD tar practice for directories
but much more work is required to achieve full semantics
of the full featured tar implementation still.
Parameters overlay module is initialized and cleared first.
It is used later to replace exception target vectors
only if that is required.
The application loader code with CPU and SDRAM setup
code has to provide well defined pattern of instructions
at addresses 0x00000000 and 0x0000001f, because only data
read accesses can be processed reliably by POM. The expected
instruction pattern can be seen in the next example
https://github.com/hornmich/tms570ls3137-hdk-sdram/blob/master/SDRAM_SCI_configuration/source/sys_intvecs.asm
Comments with detailed description of code, background
and reasons for selected approach have been included
in TMS570 bsp startup code.
Signed-off-by: Premysl Houdek <kom541000@gmail.com>
The update fixes breakage of TMS570 support after Alexander Krutwig
switch of RTEMS time read to timecounter mechanism
bsps: Convert clock drivers to use a timecounter
Mechanism to specify odd (non 1 Mhz) time base update frequencies
implemented after objections of Martin Galvan.
Code is adjusted to convert RTEMS configuration parameter
microseconds_per_tick to such odd base if
TMS570_PREFERRED_TC_FREQUENCY is specified appropriately.
The structure tms570_sci_context holds state variable
tx_chars_in_hw which holds if and how many characters
(in the optional FIFO support for some Ti SCIs) are submitted
into hardware.
When field is not writable then code breaks when RTEMS
is build for Flash area.
The problem found and analyzed by Martin Galvan from tallertechnologies.
This implementation is able to catch cast to type
which differs not only in qualifiers. The error
diagnostic message when used in function is self
descriptive. Macro is compatible with used in initializers
but there message about not constant initial value
signals types incompatibility.
The actual implementation does not distinguish between
volatile and const removal.
counters.
The code is written as BSP specific now but it should work for all
Cortex-A and R based CPUs and can be moved to ARM generic place in future.
StackOverflow suggested sequences of writes to the registers required
to start counters is used.
http://stackoverflow.com/questions/3247373/how-to-measure-program-execution-time-in-arm-cortex-a8-processor
BSP completes build with tests and debug enabled for all three variants now
tms570ls3137_hdk
tms570ls3137_hdk_intram
tms570ls3137_hdk_sdram
Even that all enabled tests builds for internal RAM variant, many
of them are expected to fail on hardware because whole tests
including code, data and runtime work area demands has to fit
into 256 kB of RAM.
requirements.
This patch enables to build all RTEMS tests for tms570ls3137_hdk_sdram
BSP variant in in default build. Debug build with --enable-rtems-debug set
has succeed for samples subset of tests as well.
digital mode for non-analog function.
The problem wit incorrect switching of pins into analog mode manifestes
on LPC4088 based board.
LPC4088 implements pin P1.17 (ENET_MDIO) as new W type (digital pin
with analog option). The pin was listed as D category on LPC1788
which does not have analog mode control bit. If analog option is
not explicitly switched off on LPC4088 then the pin does not work
as digital pin.
Code tested on LPC1788 and no problems has been observed even that
manual specifies the IOCON_ADMODE field as reserved and should
be written as zero. But even RTEMS lpc24xx_gpio_config sets this
bit unconditionally.
Signed-off-by: Pavel Pisa <ppisa@pikron.com>
Reduce MII clock to support LPC17XX.
STOP_TRANSMISSION command is used to finish READ_MULTIPLE_BLOCK
command and its format is regular command format.
It requires valid CRC-7 to have effect at least on
same cards types else it is ignored and attempt
to issue next READ or WRITE commands results in
illegal command condition (0x04) preceded by strange
(0x3f) for tested card.
CSB336 i.MX1/i.MXS memory map organization
- SDRAM starts at address 0x08000000 but 2 MB are reserved
for boot-block/loader (or other use) before RTEMS image
origin/load address (that is kept from previous setup)
- Caching of 30 MB of SDRAM used for RTEMS (start at 0x08200000)
is changed to writeback mode which provides higher throughput.
- The first 1 MB of RTEMS dedicated SDRAM is remapped to address 0
to provide area for ARM CPU exceptions table.
- Internal registers and rest of the Flash (above 1 MB) are mapped
one to one. Registers region is extended to 2 MB to cover
eSRAM found on i.MX1 chip variant.
- The first two megabytes of SDRAM unused by RTEMS are mapped
with attributes to allow specific purposes.
- the first MB (at address 0x08000000) is nocached to allow
directly set some values read by booot-block after warm reset
- the second MB (at address 0x08100000) is set for write-through
caching. That allows to use memory for LCD frame-buffer without
need to flush cache after each redraw.
Jump to start provided at address 0x08200000 allows
to load application image even as plain binary file
and start it by jump to image start address.
The initial region (64 bytes) of SDRAM RTEMS image is remapped
to provide overlay of the initial/ROM exceptions table.
This area cannot be used for MMU mapping table. Different correctly
aligned block has to be used for MMU table. Remapping of SDRAM
(address 0x08200000) to address 0 is supported only on 1 MB block
granularity and that is why SDRAM_VEC area has to be 1 MB aligned too
but unused part of remapped region can be freely used for other
purposes (as MMU tables).
The original version is missing void and result is that (*x >> 16) is
optimized to ldh rX,[rY]. But it is not allowed/supported to access
bus/address range used by AITC by other than 32 bit wide accesses
and 16-bit access results in the data abort exception.
The corrected version works on real hardware and is even
more readable.
