This change allows for the migration of higher priority tasks on the
arrival of a lower priority task limited by affinity constraints.
Change license to BSD-2-Clause according to file history and
re-licensing agreement.
Update #3053.
Move _ISR_Handler() to a separate file since it is now only used if a handler
is installed by _CPU_ISR_install_raw_handler().
Statically initialize the traps for external interrupts to use the new
_SPARC_Interrupt_trap() which directly dispatches the interrupt handlers
installed by rtems_interrupt_handler_install() via the BSP-provided
_SPARC_Interrupt_dispatch().
Since the trap table is now fully statically initialized, there is no longer a
dependency on the Cache Manager in the default configuration.
Update #4458.
Add bsp_interrupt_handler_dispatch_unchecked() as an alternative to
bsp_interrupt_handler_dispatch(). It may be used if the caller can ensure that
the vector number is valid.
This makes them usable in multiple files.
Update #4458.
Avoid using set_vector() which depends on _ISR_Vector_table(). Prepare for a
statically initialized trap table.
Update #4458.
Statically initialize the trap table in start.S to jump to _SPARC_Bad_trap()
for all unexpected traps. This enables a proper RTEMS fatal error handling
right from the start. Do not rely on the stack and register settings which
caused an unexpected trap. Use the ISR stack of the processor to do the fatal
error handling. Save the full context which caused the trap. Fatal error
handler may use it for error logging.
Unify the _CPU_Exception_frame_print() implementations and move it to cpukit.
Update #4459.
Move _CPU_ISR_install_raw_handler() and _CPU_ISR_install_vector() to separate
files. The goal is to make their use optional.
Update #4458.
Update #4459.
This makes it easier to review start.o and set break points to trap table
entries. This change was checked by inspecting the trap table in start.o with
objdump.
Update #4458.
The _ISR_Handler_initialization() does not touch the _ISR_Vector_table[]. Move
the definition of _ISR_Vector_table[] to a separate file.
Change license to BSD-2-Clause according to file history and re-licensing
agreement.
Update #3053.
This variable is actually contained in _Per_CPU_Information[] which is already
zero initialized.
Remove superfluous includes.
This CPU port macro was not used. Since the _ISR_Vector_table[] is statically
allocated, CPU ports could initialize this table in _CPU_Initialize() if
necessary. Remove _CPU_Initialize_vectors() to simplify the CPU port
interface.
Fix an off by one error.
Update #3269.
Change the default value of BSP_INTERRUPT_VECTOR_COUNT so that no interrupt
vectors are supported and all related directives return RTEMS_INVALID_ID.
Update #3269.
This define is no longer used.
Update #3269.
Use BSP_INTERRUPT_VECTOR_COUNT instead of BSP_INTERRUPT_VECTOR_MAX.
Update #3269.
Replace it with BSP_INTERRUPT_VECTOR_COUNT.
Update #3269.
Assert BSP_INTERRUPT_VECTOR_MAX + 1 == BSP_INTERRUPT_VECTOR_COUNT.
After building all BSPs with this patch, BSP_INTERRUPT_VECTOR_MAX can be
removed and replaced by BSP_INTERRUPT_VECTOR_COUNT. The
BSP_INTERRUPT_VECTOR_COUNT allows a default implementation which supports no
interrupt vector at all. Using COUNT instead of MAX may avoid some
interpretation issues, for example is the maximum value a valid vector number
or not.
Update #3269.
This define represents the last valid interrupt vector number.
Update #3269.
Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector
numbers start with zero.
The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit
and building all BSPs.
Update #3269.
After building all BSPs with this patch, this BSP-specific define can be
removed to simplify the implementation.
Update #3269.
Update #3269.
This BSP uses a customized implementation of the interrupt extension API. It
was the only BSP which defined BSP_INTERRUPT_VECTOR_MIN to a value other than
zero. Define it to zero and use a custom bsp_interrupt_is_valid_vector()
function instead.
Update #3269.
Remove the support for BSP_INTERRUPT_NO_HEAP_USAGE. This was only used
by one BSP and provides no real benefit.
Update #3269.
Close #4461.
Fix compile error with RTEMS_DRVMGR_STARTUP = True.
This adds the possibility to open an I2C bus with O_NONBLOCK (or set it
later via fcntl) to get non-blocking transmissions. This means that if
the bus is busy, a read, write or transfer ioctl will return with a
EAGAIN errno.
The write to RBAR didn't have the valid flag set. Therefore the write to
RASR had an influence on the previously set region. That means for
example that if Region 0 had been enabled but 1 should be disabled due
to a size of 0, the previous code would have disabled region 0 instead.
This patch fixes that behaviour.
Close #4450
Don't initialze regions that have a negative size (for example due to a
wrong calculation).
Update #4450
Closes #4455
Update #3053.
Callers usually want to output a character.
This is already done in rtems_putc().
Get rid of the hack to output into the idle stack during the early system
initialization. This fixes also a couple of test program failures which fail
due to missing output.
Replace the global variable ambapp_plb with a function to allow an automatic on
demand initialization.
Make the memory allocations in ambapp_scan() customizable via the new struct
ambapp_context parameter which generalizes the memory copy handler.
Update #4202.
The change also helps to avoid reports from static analysers since most
callers of _Thread_queue_Make_ready_again() check the unblock status.
Mention the type of the pointer in the parameter description. Use the
more general term "object" instead of "variable".
Update #3993.
Make the initialization of the per-CPU data optional.
Update #3053.
Make sure that the linker sets work if placed in a library (this is how
they are used in RTEMS).
Directly initialize the memory in the start sequence defined by start.S
instead of using a system initialization handler. This avoids using the
global variable rdb_start which used a memory location which was shared
with _ERC32_MEC_Timer_Control_Mirror. This change makes it possible to
use _Memory_Allocate() even before the system initialization is started.
Update #3053.
Initialize the stacks for all processors in one place. Do not rely on
Per_CPU_Control::interrupt_stack_high and directly use the statically
allocated interrupt stack area.
