* | changed version to 19991123-rc | Joel Sherrill | 1999-11-23 | 1 | -1/+1 |
* | Added Timer Manager Chapter. | Joel Sherrill | 1999-11-23 | 2 | -1/+8 |
* | Fixed line too long. | Joel Sherrill | 1999-11-23 | 1 | -2/+2 |
* | New file. | Joel Sherrill | 1999-11-23 | 1 | -0/+196 |
* | Readding files mistakenly removed. | Joel Sherrill | 1999-11-23 | 40 | -0/+2289 |
* | Patch rtems-rc-19991117-16.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-11-23 | 12 | -16/+32 |
| | | | | | | | * the PACKHEX etc problem * prevents the *.rels being removed inside the build-tree * a typo which only shows for when MP is activated * Alters some custom/*cfg files | ||||
* | Readding Makefile.in's accidentally removed. | Joel Sherrill | 1999-11-23 | 1 | -0/+33 |
* | *** empty log message *** | Joel Sherrill | 1999-11-23 | 1 | -27/+21 |
* | Moved pmacros.h to include not support/include. | Joel Sherrill | 1999-11-23 | 38 | -131/+42 |
* | Patch rtems-rc-19991117-15.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 4 | -132/+75 |
| | | | | to convert the tests/support directory from Makefile.in to Makefile.am. | ||||
* | Missed in previous automake conversion patches from Ralf Corsepius | Joel Sherrill | 1999-11-23 | 14 | -0/+492 |
| | | | | <corsepiu@faw.uni-ulm.de>. | ||||
* | Miscellaneous patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 30 | -235/+1246 |
| | | | | | that are part of the Makefile.am conversion effort but were missed in the previous commits. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 16 | -36/+26 |
| | | | | to convert the libmisc directory from Makefile.in to Makefile.am. | ||||
* | Added clock06.c to the compile list. | Joel Sherrill | 1999-11-23 | 2 | -8/+4 |
* | Files only used by psxfile01, so moved there. | Joel Sherrill | 1999-11-23 | 9 | -11/+202 |
* | Test psxfile02 unused and removed. | Joel Sherrill | 1999-11-23 | 3 | -5/+2 |
* | Unused and removed. | Joel Sherrill | 1999-11-23 | 4 | -119/+0 |
* | Patch rtems-rc-19991117-14.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 81 | -2020/+2094 |
| | | | | to convert the psxtests directory from Makefile.in to Makefile.am. | ||||
* | Patch rtems-rc-19991117-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 2 | -0/+46 |
| | | | | to convert the libtests directory from Makefile.in to Makefile.am. | ||||
* | Patch rtems-rc-19991117-13.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 28 | -589/+718 |
* | Patch rtems-rc-19991117-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 95 | -2297/+2794 |
| | | | | to convert the tmtests directory from Makefile.in to Makefile.am. | ||||
* | Patch rtems-rc-19991117-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 83 | -3219/+1126 |
| | | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib." | ||||
* | Added projects chapter to FAQ. | Joel Sherrill | 1999-11-23 | 3 | -2/+122 |
* | Patch rtems-rc-19991117-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-22 | 236 | -535/+709 |
* | Patch rtems-rc-19991117-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-22 | 78 | -78/+4 |
| | | | | to fix some minor bugs in the conversion to automake. | ||||
* | Patch rtems-rc-19991117-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-22 | 32 | -720/+928 |
| | | | | to convert the sample tests to automake. | ||||
* | Converted to automake. | Joel Sherrill | 1999-11-22 | 88 | -3004/+2240 |
* | Now replaced by an automake file. | Joel Sherrill | 1999-11-22 | 1 | -360/+0 |
* | Corrected. | Joel Sherrill | 1999-11-22 | 1 | -5/+1 |
* | Added ifndef around build_time so pmacros.h and tmacros.h could be included | Joel Sherrill | 1999-11-22 | 2 | -0/+4 |
| | | | | by the same application. | ||||
* | tmitrontests directory listed twice. | Joel Sherrill | 1999-11-22 | 1 | -1/+1 |
* | Fixed dispatching and cleaned up code. | Jennifer Averett | 1999-11-22 | 4 | -60/+28 |
* | + Corrected enable/disable of dispatch. | Jennifer Averett | 1999-11-22 | 2 | -46/+62 |
| | | | | + Cleaned up code. | ||||
* | + Updated comments. | Jennifer Averett | 1999-11-22 | 2 | -18/+40 |
| | | | | + Corrected enable/disable of dispatch. | ||||
* | + Corrected bug in error check. | Jennifer Averett | 1999-11-22 | 2 | -4/+2 |
* | + Added description of routine to comment. | Jennifer Averett | 1999-11-22 | 2 | -0/+8 |
* | + Corrected error processing code. | Jennifer Averett | 1999-11-22 | 2 | -28/+30 |
* | + Added checks for NULL and NULL string names (for sem_open & sem_unlink). | Jennifer Averett | 1999-11-22 | 2 | -2/+14 |
* | + Cleaned up comments. | Jennifer Averett | 1999-11-22 | 2 | -12/+32 |
* | + Corrected error messages. | Jennifer Averett | 1999-11-22 | 2 | -60/+160 |
| | | | | | | | | + Added tests for sem_open, sem_close, and sem_unlink. + Yellow lined sem_open, sem_close, sem_unlink, _POSIX_Semaphore_Delete, _POSIX_Semaphore_Name_to_id, and _POSIX_Semaphore_Create_support. Except for MP, pshared OBJECT_REMOTE, and out of memory paths. | ||||
* | RTEMS RPM basically working. | Joel Sherrill | 1999-11-22 | 5 | -20/+30 |
* | Removed need for START_BASE. | Joel Sherrill | 1999-11-22 | 14 | -42/+1 |
* | Added ifndef around build_time macro so tmacros.h and pmacros.h | Joel Sherrill | 1999-11-22 | 3 | -0/+6 |
| | | | | can be included from the same file. | ||||
* | Use PGM consistently. | Joel Sherrill | 1999-11-22 | 2 | -3/+3 |
* | Made it agree on PGM versus PGM/PGMS. | Joel Sherrill | 1999-11-22 | 3 | -3/+3 |
* | Changed name of W, X, and Y macros for fields in the Clock | Joel Sherrill | 1999-11-22 | 3 | -27/+27 |
| | | | | Synthesizer Control Register to remove use of single letter names. | ||||
* | Adding files missed by earlier merger of SH-2. | Joel Sherrill | 1999-11-22 | 1 | -0/+153 |
* | Added files missed by previous merger of SH-2 port. | Joel Sherrill | 1999-11-22 | 5 | -0/+624 |
* | Adding files not added as part of merger of SH2 port. | Joel Sherrill | 1999-11-22 | 6 | -0/+1706 |
* | Removed unneeded directory. | Joel Sherrill | 1999-11-22 | 1 | -87/+0 |
