* mpc6xx/mmu/pte121.c: Eliminate unsigned32.
* mpc8xx/clock/clock.c: Eliminate rtems_unsigned32.
* libi2c/libi2c.c: Include config.h.
* libi2c/libi2c.c, libi2c/libi2c.h,
libnetworking/rtems/rtems_mii_ioctl.h,
libnetworking/rtems/rtems_mii_ioctl_kern.c,
score/src/heap.c: Eliminate obsolete types.
* libchip/i2c/i2c-2b-eeprom.c: Eliminate obsolete types.
* libchip/rtc/mc146818a.h: Eliminate obsolete types.
* shared/irq/idt.c: Reflect API changes.
* timer/timer.c: Remove C++-style comments.
* libchip/network/dec21140.c, libchip/network/elnk.c: Use
libcpu/byteorder.h for i386.
* Makefile.am: Add preinstall.am
* preinstall.am: New.
* configure.ac: Add AMPOLISH3.
* byteorder.h: New.
* shared/include/byteorder.h: Remove __arch_swap (Unused).
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* Makefile.am: Distibute mongoosev's READMEs
* Makefile.am: Partially cleanup EXTRA_DIST.
* shared/vmeUniverse/vmeTsi148.c, shared/vmeUniverse/vmeTsi148.h,
shared/vmeUniverse/vme_am_defs.h: New files.
* Makefile.am, shared/vmeUniverse/README.universe,
shared/vmeUniverse/vmeUniverse.c, shared/vmeUniverse/vmeUniverse.h:
Several VME related upgrades and fixes, hopefully addressing PR#835:
vmeUniverse driver now supports shared interrupts. vmeUniverse now
supports up to four wires between universe and PIC. A new irq mgr
installation routine has been added allowing to use the new features.
(old version is still present for bwd compatibility). Calls have been
added to change interrupt routing (e.g., if wires have different
priorities at the PIC this feature can be used to configure
priorites). Routine for testing VME interrupts has been added (useful
during BSP development). A new header defining standard VME address
modes has been added so that the VME API doesn't have to #include a
particular bridge driver header. For all driver entry points, a 'XX'
variant has been added which allows to pass the chip's base address
[in case a second universe is sitting on a VME card :-)]. Driver now
uses interrupt line as read from PCI config. space (without offset)
BSP needs to use PCI fixup if necessary. Added a driver for the
tundra tsi148 VME bridge.
* shared/vme/README, shared/vme/vme_universe.c: New files.
* Makefile.am, motorola_powerpc/Makefile.am, mvme5500/vme/vmeconfig.c,
shared/vme/VME.h, shared/vme/VMEConfig.h, shared/vme/vmeconfig.c:
Separated API, API-implementation by a specific VME bridge driver and
BSP-specific configuration of the driver into different files,
describing their purpose in a README. All of these changes use the
upgraded vmeUniverse.c driver.
* include/bsp.h, vme/vmeconfig.c: Reverted redefinition of _IO_BASE;
this normally points to ISA space but is misused by this BSP
(inb/outb & friends are all over the place).
* custom/mvme5500.cfg: Fixed PR#846; must not use -mcpu=74xx, use
-mcpu=750 instead.
* irq/irq.c, irq/irq.h: removed BSP_SHARED_HANDLER_SUPPORT definition;
this BSP does not implement sharing interrupts.
* shared/motorola/motorola.c, shared/pci/detect_raven_bridge.c,
shared/pci/pci.c, shared/pci/pci.h, shared/pci/pcifinddevice.c:
Several PCI enhancements and fixes: all BSP flavors now use the
generic clear_hostbridge_errors() routine (this means that only
polling memory probing is possible [see detect_raven_bridge.c for
details]). Interrupt fixup routine now supports multi-function
devices. Interrupt fixup routine now honours a flag/option so that
wrong firmware values can be overridden. Fixed irq routing table for
mvme2100 [PMC]. Added irq routing table for mvme2300. Added a
BSP_pciScan() routine that executes a user callback on each non-empty
slot/fun. Added BSP_pciConfigDump() to display basic config headers.
* include/bsp.h: fixed misuse of _IO_BASE
* shared/console/reboot.c, shared/start/start.S: Fixed PR#845;
!!enable MMU!! on mvme2100 - this is very important.
Otherwise, all accesses are write-back cached [incl. memory-mapped devices].
(Prerequisite were the changes to shared/startup/bspstart.c just
below.) Implemented rtemsReboot() for mvme2100.
* shared/irq/openpic_i8259_irq.c: New file.
* ChangeLog, Makefile.am, motorola_powerpc/ChangeLog,
motorola_powerpc/Makefile.am, shared/irq/irq.c, shared/irq/irq.h,
shared/irq/irq_asm.S, shared/irq/irq_init.c: Separated openpic/i8259
specifica from generic irq handling into openpic_i8259_irq.c; added
some compilation conditionals to help BSPs without ISA to omit ISA
interrupts and calling i8259 code.
* Makefile.am, include/bsp.h: Added new shared pretaskinghook.c and
zerobss.c files to list to be made. Added some explanations about
CPU <-> PCI <-> VME address mapping issues.
* shared/startup/pretaskinghook.c, shared/startup/zerobss.c: New files.
* Makefile.am, shared/startup/bspstart.c: Split
pretaskinghook and zerobss into separate, reusable files; Fixed
#PR837 (set exception in ram flag before initializing exceptions);
Setup DBATs early, they are needed to access peripherals (Allows
mvme2100 to use MMU); moved VME initialization into pretasking hook
so that shared interrupts can be used for VME [shared IRQ facility
needs functional workspace].
* mvme5500/irq/irq.h, psim/irq/irq.h, shared/console/uart.c,
shared/irq/irq.h: Renamed BSP_ISA_UART_COMx_IRQ -> BSP_UART_COMx_IRQ
(uart driver is ISA independent).
Removed ugly #ifdef mvme2100. Added test for
BSP_UART_USE_SHARED_IRQS symbol which a BSP can define to request
that the serial interrupt be shared.
* ChangeLog: corrected list of affected files
* shared/vectors/vectors.S: when returning
from an exception, reload stack pointer with value from exception
frame instead of adding a fixed value. -- maybe the exception handler
modified the frame with good reason (e.g., gdb pushed a dummy frame).
* Makefile.am, motorola_powerpc/Makefile.am, mvme5500/Makefile.am,
mvme5500/start/preload.S, mvme5500/startup/bspstart.c,
shared/startup/bspstart.c: moved linkcmds to shared area for other
BSPs to use
