* Makefile.am: Cleanup.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am: Cleanup.
* tmitrontests.am: Add $(PGM): ${ARCH}/$(dirstamp).
* tmitronsem01/Makefile.am:
Partial conversion to automake.
* mptests.: Add $(PGM): ${ARCH}/$(dirstamp).
* mp01/node1/Makefile.am, mp01/node2/Makefile.am,
mp02/node1/Makefile.am, mp02/node2/Makefile.am,
mp03/node1/Makefile.am, mp03/node2/Makefile.am,
mp04/node1/Makefile.am, mp04/node2/Makefile.am,
mp05/node1/Makefile.am, mp05/node2/Makefile.am,
mp06/node1/Makefile.am, mp06/node2/Makefile.am,
mp07/node1/Makefile.am, mp07/node2/Makefile.am,
mp08/node1/Makefile.am, mp08/node2/Makefile.am,
mp09/node1/Makefile.am, mp09/node2/Makefile.am,
mp10/node1/Makefile.am, mp10/node2/Makefile.am,
mp11/node1/Makefile.am, mp11/node2/Makefile.am,
mp12/node1/Makefile.am, mp12/node2/Makefile.am,
mp13/node1/Makefile.am, mp13/node2/Makefile.am,
mp14/node1/Makefile.am, mp14/node2/Makefile.am:
* tmtests.am: Add $(PGM): ${ARCH}/$(dirstamp).
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am,
tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am,
tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am,
tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am,
tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am,
tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am,
tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am,
tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am,
tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am,
tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am,
tmoverhd/Makefile.am:
* psxtests.am: Add $(PGM): ${ARCH}/$(dirstamp).
psx13/Makefile.am, psxcancel/Makefile.am, psxchroot01/Makefile.am,
psxfile01/Makefile.am, psxhdrs/Makefile.am, psxmount/Makefile.am,
psxmsgq01/Makefile.am, psxreaddir/Makefile.am, psxsem01/Makefile.am,
psxstat/Makefile.am, psxtime/Makefile.am, psxtimer/Makefile.am:
* itrontests.am: Add $(PGM): ${ARCH}/$(dirstamp).
* itronhello/Makefile.am, itronmbf01/Makefile.am,
itronmbox01/Makefile.am, itronsem01/Makefile.am,
itrontask01/Makefile.am, itrontask02/Makefile.am,
itrontask03/Makefile.am, itrontask04/Makefile.am,
itrontime01/Makefile.am:
* sptests.am: Add $(PGM): ${ARCH}/$(dirstamp).
sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am,
spfatal/Makefile.am, spsize/Makefile.am:
* automake/amcompile.am: New.
* libtests.am: Add $(PGM): ${ARCH}/$(dirstamp).
* cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am,
stackchk/Makefile.am, termios/Makefile.am:
* sample.am: Add $(PGM): ${ARCH}/$(dirstamp).
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, cdtest/Makefile.am, fileio/Makefile.am,
hello/Makefile.am, iostream/Makefile.am, loopback/Makefile.am,
minimum/Makefile.am, paranoia/Makefile.am, pppd/Makefile.am,
ticker/Makefile.am, unlimited/Makefile.am:
* console/console.c: Eliminate unsigned32, unsigned8.
* include/bsp.h: Eliminate unsigned32.
* startup/bspstart.c: Eliminate unsigned32.
* network/network.c: Several minor bug fixes.
* mpc6xx/mmu/pte121.c: Eliminate unsigned32.
* mpc8xx/clock/clock.c: Eliminate rtems_unsigned32.
* libi2c/libi2c.c: Include config.h.
* libi2c/libi2c.c, libi2c/libi2c.h,
libnetworking/rtems/rtems_mii_ioctl.h,
libnetworking/rtems/rtems_mii_ioctl_kern.c,
score/src/heap.c: Eliminate obsolete types.
* libchip/i2c/i2c-2b-eeprom.c: Eliminate obsolete types.
* libchip/rtc/mc146818a.h: Eliminate obsolete types.
* shared/irq/idt.c: Reflect API changes.
* timer/timer.c: Remove C++-style comments.
* libchip/network/dec21140.c, libchip/network/elnk.c: Use
libcpu/byteorder.h for i386.
* Makefile.am: Add preinstall.am
* preinstall.am: New.
* configure.ac: Add AMPOLISH3.
* byteorder.h: New.
* shared/include/byteorder.h: Remove __arch_swap (Unused).
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* Makefile.am: Distibute mongoosev's READMEs
