* | bsp/qoriq: Fix L1 cache flush | Sebastian Huber | 2017-04-03 | 1 | -6/+13 |
* | bsp/qoriq: Adjust MMU config only once | Sebastian Huber | 2017-04-03 | 3 | -5/+10 |
* | bsp/qoriq: Add post-link hook | Sebastian Huber | 2017-04-03 | 1 | -0/+7 |
* | bsps: Fix baud settings | Sebastian Huber | 2017-04-03 | 8 | -12/+10 |
| | | | | Update #2897. | ||||
* | configure: Remove defunct configure stuff | Sebastian Huber | 2017-04-03 | 1 | -2/+0 |
* | libdl: Support link ordered loading of ELF sections. | Chris Johns | 2017-03-31 | 6 | -1341/+1523 |
| | | | | | | | | | | | | | The ARM C++ exception ABI uses an address ordered index table to locate the correct frame data and this requires the EXIDX sections are loaded in the order the order the matching text is loaded. The EXIDX sections set the SHF_LINK_ORDER flag and link field. This patch adds support to load those flagged sections in the linked-to section order. Updates #2955. Closes #2959 | ||||
* | benchmarks/whetstone: Port to RTEMS | Sebastian Huber | 2017-03-29 | 5 | -15/+39 |
| | | | | Update #2958. | ||||
* | benchmarks/whetstone: Import | Sebastian Huber | 2017-03-29 | 1 | -0/+433 |
| | | | | | | | | Import whetstone sources from: http://www.netlib.org/benchmark/whetstone.c Update #2958. | ||||
* | benchmarks/linpack: Port to RTEMS | Sebastian Huber | 2017-03-29 | 5 | -180/+109 |
| | | | | Close #2958. | ||||
* | benchmarks/linpack: Import | Sebastian Huber | 2017-03-29 | 1 | -0/+1333 |
| | | | | | | | | Import linpack sources from: http://www.netlib.org/benchmark/linpack-pc.c Update #2958. | ||||
* | benchmarks/dhrystone: Port to RTEMS | Sebastian Huber | 2017-03-29 | 7 | -33/+128 |
* | benchmarks/dhrystone: Import | Sebastian Huber | 2017-03-29 | 6 | -0/+1596 |
| | | | | | | | | Import dhrystone sources from: http://www.netlib.org/benchmark/dhry-c Update #2958. | ||||
* | benchmarks: Add benchmark templates | Sebastian Huber | 2017-03-29 | 15 | -1/+273 |
* | arm: Optimize context switch | Sebastian Huber | 2017-03-28 | 4 | -90/+55 |
| | | | | | | | | | Set CPU_ENABLE_ROBUST_THREAD_DISPATCH to TRUE. In this case the interrupts are always enabled during a context switch even after interrupt processing (see #2751). Remove the CPSR from the context control since it contains only volatile bits. Close #2954. | ||||
* | posix: Fix pthread_detach() internal lock acquire | Sebastian Huber | 2017-03-28 | 1 | -1/+1 |
* | rtems: Fix error return path | Sebastian Huber | 2017-03-28 | 1 | -0/+1 |
* | cpukit: Fix Makefile.am and update preinstall.am | Sebastian Huber | 2017-03-27 | 2 | -18/+20 |
* | bsp/qoriq: Regenerate preinstall.am | Sebastian Huber | 2017-03-27 | 1 | -4/+0 |
* | bsp/tms570: Use shared benchmark timer | Sebastian Huber | 2017-03-27 | 2 | -62/+1 |
* | bsps: Add simple CPU counter benchmark timer | Sebastian Huber | 2017-03-27 | 1 | -0/+35 |
* | bsp/tms570: Simplify CPU counter support | Sebastian Huber | 2017-03-27 | 1 | -63/+13 |
| | | | | Only touch the cycle counter settings. Do not enable user mode access. | ||||
* | bsps/arm: Add Performance Monitors Extension | Sebastian Huber | 2017-03-27 | 1 | -1/+446 |
* | bsp/tms570: Simplify <bsp.h> | Sebastian Huber | 2017-03-27 | 1 | -12/+0 |
* | bsp/tms570: Remove OPERATION_COUNT define | Sebastian Huber | 2017-03-27 | 1 | -3/+0 |
| | | | | This is the wrong place to define it. | ||||
* | termios: Avoid invalid memory access | Sebastian Huber | 2017-03-27 | 1 | -1/+3 |
* | termios: Synchronize with latest FreeBSD headers | Kevin Kirspel | 2017-03-22 | 77 | -658/+1393 |
| | | | | | | | | | | | Adding modified FreeBSD headers to synchronize RTEMS termios with FreeBSD. Modify termios to support dedicated input and output baud for termios structure. Updated BSPs to use dedicated input and output baud in termios structure. Updated tools to use dedicated input and output baud in termios structure. Updated termios testsuites to use dedicated input and output baud in termios structure. Close #2897. | ||||
* | bsp/atsam: Fix DMA support of some drivers | Sebastian Huber | 2017-03-22 | 3 | -0/+3 |
* | dosfs: Fix file name search | Sebastian Huber | 2017-03-16 | 2 | -18/+17 |
| | | | | | | | Do not use our long file name entry count to optimize the file name search. The Unicode comparison must be taken into account. Update #2939. | ||||
* | dosfs: Fix race condition msdos_dir_read() | Sebastian Huber | 2017-03-16 | 1 | -5/+5 |
| | | | | | | Obtain file system instance lock before member access. Update #2937. | ||||
* | dosfs: Rename fat_entries to lfn_entries | Sebastian Huber | 2017-03-16 | 1 | -20/+20 |
| | | | | | The name "fat_entries" for long file name directory entries is quite misleading. | ||||
* | dosfs: Fix long file name padding | Sebastian Huber | 2017-03-16 | 1 | -3/+3 |
| | | | | Update #2934. | ||||
* | dosfs: msdos_filename_utf8_to_short_name_for_save | Sebastian Huber | 2017-03-16 | 1 | -15/+10 |
| | | | | Simplify. | ||||
* | dosfs: Fix msdos_add_file() | Sebastian Huber | 2017-03-16 | 1 | -245/+155 |
| | | | | | | Make sure that long file names work accross cluster boundaries. Update #2929. | ||||
* | dosfs: Simplify msdos_add_file() | Sebastian Huber | 2017-03-16 | 1 | -4/+2 |
* | dosfs: Add and use msdos_lfn_checksum() | Sebastian Huber | 2017-03-16 | 3 | -22/+25 |
* | dosfs: Simplify fat_file_open() | Sebastian Huber | 2017-03-16 | 1 | -3/+1 |
* | dosfs: Simplify msdos_creat_node() | Sebastian Huber | 2017-03-16 | 1 | -21/+14 |
* | dosfs: Fix fat_file_write() | Sebastian Huber | 2017-03-16 | 10 | -36/+183 |
| | | | | | | | | Remove forced overwrite which leads to file data corruption. The logic to determine a forced overwrite was fundamentally broken. For simplity, disable this feature. Update #2622. | ||||
* | dosfs: Fix msdos_utf8_normalize_and_fold() | Sebastian Huber | 2017-03-16 | 2 | -5/+22 |
| | | | | | | | | It is all right in case the result uses the full destination buffer. Without this fix the handling of a maximum 8.3 short file name is broken. Update #2928. | ||||
* | libio: Fix deadlock in location management | Sebastian Huber | 2017-03-16 | 8 | -17/+21 |
| | | | | | | | | Perform a context-dependent deferred location release to avoid a deadlock on the file system instance locks, for example during a chdir(). Update #2936. | ||||
* | psxstrsignal01: New test | Joel Sherrill | 2017-03-15 | 6 | -1/+198 |
* | tools/build/eolstrip.c: Use snprintf() to avoid potential buffer overflow | Joel Sherrill | 2017-03-14 | 1 | -1/+3 |
| | | | | This was spotted by Coverity Scan. | ||||
* | libchip/serial/mc68681.c: Add error check | Joel Sherrill | 2017-03-14 | 1 | -0/+2 |
* | Fix rtems-test-check with a BSD sed. | Chris Johns | 2017-03-14 | 2 | -6/+6 |
| | | | | | BSD sed does not support '\t' and treated '[ \t]' as 3 characters. This patch uses a standard method of supporting blank spaces. | ||||
* | libbsp/mips/shared/irq/i8259.c: Add include of rtems/bspIo.h | Joel Sherrill | 2017-03-09 | 1 | -0/+1 |
* | libbsp/shared/clock/clockdrv.c: Remove unneeded printk() | Joel Sherrill | 2017-03-09 | 1 | -1/+0 |
* | libbsp/malta/pci/pci.c: Correct printk() formats | Joel Sherrill | 2017-03-09 | 1 | -6/+6 |
* | libbsp/csb350/clock/clockdrv.c: Remove unneeded printk() | Joel Sherrill | 2017-03-09 | 1 | -3/+0 |
* | libbsp/mips/shared/irq.c: Fix warnings | Joel Sherrill | 2017-03-09 | 2 | -41/+11 |
* | arm: Fix CPU context validation for Cortex-R4 | Sebastian Huber | 2017-03-09 | 2 | -7/+3 |
| | | | | Do not touch the FPSCR[QC] bit since this is DNM/RAZ on Cortex-R4. |
