* | Merged newlib's libgloss support for rtems into this directory. This | Joel Sherrill | 1997-01-29 | 15 | -106/+254 | |
| | | | | should simplify the build process. | |||||
* | All RTEMS system call implementation renamed to be __rtems_*. | Joel Sherrill | 1997-01-29 | 21 | -85/+123 | |
* | The CONSOLE_USE_INTERRUPTS and CONSOLE_USE_POLLED macros are now | Joel Sherrill | 1997-01-29 | 1 | -7/+1 | |
| | | | | defined in the targopts.h file. | |||||
* | Removed definitions which are now in targopts.h. This eliminates the | Joel Sherrill | 1997-01-29 | 12 | -232/+12 | |
| | | | | | need for the "sed'ing" of this file. This should be a significant win when addressing non-unix host and non-gnu toolsets. | |||||
* | added type to macro to eliminate warning for untyped use of a register. | Joel Sherrill | 1997-01-29 | 3 | -3/+3 | |
* | Added comment. | Joel Sherrill | 1997-01-29 | 1 | -1/+1 | |
* | Removed defines now handled by targopts.h. | Joel Sherrill | 1997-01-29 | 1 | -22/+0 | |
* | Added include of rtems/score/cpu.h | Joel Sherrill | 1997-01-29 | 1 | -1/+0 | |
* | Added include of targopts.h. | Joel Sherrill | 1997-01-29 | 22 | -13/+35 | |
* | Changed include of asm.h so it is in brackets not quotes. asm.h is | Joel Sherrill | 1997-01-29 | 2 | -2/+2 | |
| | | | | in a standard location and should be referenced as such. | |||||
* | Fixed spacing on comments. | Joel Sherrill | 1997-01-29 | 1 | -1/+1 | |
* | Fixed spacing on comment. | Joel Sherrill | 1997-01-29 | 1 | -1/+1 | |
* | Fixed comments. | Joel Sherrill | 1997-01-29 | 1 | -1/+6 | |
| | | | | Fixed so this file can be included from assembly code. | |||||
* | fixed spacing problem | Joel Sherrill | 1997-01-29 | 1 | -1/+1 | |
* | With the transition from command line macro definitions to targopts.h, | Joel Sherrill | 1997-01-28 | 2 | -6/+4 | |
| | | | | | it was necessary to include system.h before checking if anything was defined. | |||||
* | removed include of unnecessary include file. | Joel Sherrill | 1997-01-28 | 2 | -2/+0 | |
* | Switch to using newlib's implementation of time(). | Joel Sherrill | 1997-01-28 | 2 | -0/+6 | |
* | new file used by gcc 2.8.x -specs option | Joel Sherrill | 1997-01-28 | 18 | -0/+612 | |
* | fixed comments on vanilla 68000 SW interrupt stack (or the lack thereof) | Joel Sherrill | 1997-01-15 | 3 | -7/+4 | |
* | _CPU_Trap_Table_area is now conditional based on whether or not | Joel Sherrill | 1997-01-08 | 2 | -4/+10 | |
| | | | | the application requires rtems to allocate a trap table | |||||
* | removed assert() for stat on non-devices. Now it returns -1. This | Joel Sherrill | 1997-01-08 | 1 | -2/+1 | |
| | | | | makes gnat pass about 55 more tests in the acvc. | |||||
* | added some casts to reduce warnings reported by users with Microtec C++ | Joel Sherrill | 1997-01-08 | 8 | -56/+70 | |
| | | | | compiler. | |||||
* | added type definitions for all supported task entry formats | Joel Sherrill | 1997-01-08 | 3 | -3/+18 | |
* | Suggested changes from Mark Jordan which eliminate warnings and errors | Joel Sherrill | 1996-12-02 | 15 | -30/+41 | |
| | | | | | | | | he received using the Microtec C++ compiler. Most of these are either missing casts from/to (void *), heavy handed use of enumerated types, or simply assumed conversions. There is at least one actual bug in an error path in thread.c in which the wrong argument was passed to _Thread_Stack_Free and was not being caught by gcc. | |||||
* | Changes to reflect new revision of erc32 per Jiri Gaisler's suggestions. | Joel Sherrill | 1996-12-02 | 8 | -38/+77 | |
| | | | | This is current as of sis 2.6. | |||||
* | minor changes to eliminate warnings from C++ compilers per user suggesstions. | Joel Sherrill | 1996-12-02 | 1 | -4/+4 | |
* | Replacement for the sis bsp which supports the simulator and real | Joel Sherrill | 1996-12-02 | 4 | -0/+1184 | |
| | | | | | hardware. From Jiri Gaisler <jgais@wd.estec.esa.nl>. Supports sis 2.6 and later. | |||||
* | New bsp for the erc32/sis from Jiri Gaisler <jgais@wd.estec.esa.nl> which | Joel Sherrill | 1996-12-02 | 2 | -0/+273 | |
| | | | | | | runs on either the real hardware or the sparc instruction simulator. This bsp requires sis version 2.6 or later. This bsp supercedes the sis bsp. | |||||
* | Updates from Derrick Ostertag <ostertag@transition.com> to fix bug in | Joel Sherrill | 1996-12-02 | 5 | -23/+63 | |
| | | | | interrupt handling. | |||||
* | Update from Chris Johns <cjohns@awa.com.au> to add better support for | Joel Sherrill | 1996-12-02 | 4 | -25/+75 | |
| | | | | 68000 class CPUs. | |||||
* | Added asserts for unhandled conditions which need to result in error | Joel Sherrill | 1996-11-08 | 4 | -3/+33 | |
| | | | | | | statuses being returned to gnat runtime in order for it to raise use_errors. This was needed to identify the places in gnat's runtime which needed to be addressed. | |||||
* | added ENOSYS support | Joel Sherrill | 1996-10-15 | 3 | -0/+3 | |
* | updated to format of 3.6.0 | Joel Sherrill | 1996-10-15 | 2 | -42/+102 | |
* | updated to format of 3.6.0 console drivers | Joel Sherrill | 1996-10-15 | 1 | -51/+111 | |
* | updated to format of 3.6.0 clock drivers | Joel Sherrill | 1996-10-15 | 1 | -24/+83 | |
* | added support for cpu time used field in tcb | Joel Sherrill | 1996-10-15 | 2 | -0/+32 | |
* | added cpu time used field to tcb | Joel Sherrill | 1996-10-15 | 3 | -0/+3 | |
* | added i386ex from Erik Ivanenko | Joel Sherrill | 1996-10-15 | 1 | -0/+3 | |
* | new file | Joel Sherrill | 1996-10-15 | 1 | -0/+8 | |
* | reference to Force CPU-386 removed. | Joel Sherrill | 1996-10-15 | 1 | -3/+20 | |
| | | | | added standard comments about driver entries. | |||||
* | initial version from Erik | Joel Sherrill | 1996-10-15 | 10 | -0/+1038 | |
* | patches to erc32.h to correct handling of timer mirror from Jiri Gaisler. | Joel Sherrill | 1996-10-14 | 2 | -6/+6 | |
* | i386_nofp cpu model entry incorrectly had floating point enabled. | Joel Sherrill | 1996-10-01 | 1 | -1/+1 | |
* | changed INLINE to inline since INLINE is no longer defined by RTEMS | Joel Sherrill | 1996-09-30 | 2 | -2/+2 | |
* | fixed incorrect placement of CPU_STRUCTURE_ALIGNMENT macro. | Joel Sherrill | 1996-09-30 | 2 | -4/+4 | |
* | changed version string to 3.6.0 | Joel Sherrill | 1996-09-30 | 2 | -2/+2 | |
* | changed stack size of posix initialization threads to double the minimum | Joel Sherrill | 1996-09-30 | 2 | -0/+6 | |
| | | | | stack size so more of acvc would pass. | |||||
* | updated for Release 3.6.0 to reflect status of posix threads. | Joel Sherrill | 1996-09-30 | 1 | -3/+14 | |
* | data and control addresses were swapped for channel a of the scc | Joel Sherrill | 1996-09-27 | 1 | -2/+2 | |
