<corsepiu@faw.uni-ulm.de> that addresses a couple of
minor configuration issues which popped up when
experimenting with multilibs.
Note: The multigen generated make/custom/bare-*.cfg will still be
non-functional, even after having applied this patch.
are his notes:
installation prefix).
mpc8xx libcpu support for the first time and remove includes
of bsp.h, references to BSP_Configuration, and Cpu_table. All
of these can be obtained directly from RTEMS now.
responsibility to explicitly pick up the components they
require. This makes it easier to override default implmentations.
score/cpu/powerpc.
shared source code.
relative srcdir issue
have them.
from cvs by adding .cvsignore files.
of all FIO constants and conflict with libnetworking code.
significant things:
and PowerPC
same code base.
John reports this works on the 821 and 860.
significant things:
and PowerPC
same code base.
significant things:
and PowerPC
same code base.
something indicates this. Eventually this needs to be merged into
gcc.
<corsepiu@faw.uni-ulm.de> that makes the following changes:
* Don't use a temporary file for ch19.texi anymore
* pass all files to be handled by summarize as commandline arguments
* Remove a dangling empty first line in posix1003_1.texi (texi2html
(!) expects \input texinfo on the first line)
on RELEASE versus VERSION.
location in libc.
to do polled IO on a single port with VERY little support code.
by gdb 5.0's i960 simulator) is enough to run hello world.
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
