* custom/pc386.cfg (make-exe): Removed commented out lines that
were displayed in build longs.
* wrapup/Makefile.am: Remove warning missed in shmsupp removal.
* Shared memory support removed since it was non-functional.
* shmsupp/.cvsignore, shmsupp/Makefile.am, shmsupp/addrconv.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c: Removed.
* configure.in, Makefile.am, wrapup/Makefile.am: Modified to
reflect above.
* src/threadinitialize.c: Fix my bad hack of Ralf's fp_area
warning removal patch. :(
* src/threadinitialize.c: Removed warning.
* start/start.S: init_exc_vecs is now called mips_install_isr_entries.
* wrapup/Makefile.am: Corrected to reflect new libcpu structure.
* console/vt.c: Added include of <rtems.h> so _CPU_ISR_disable
would be visible.
* include/bsp.h: Added closing brace for extern C.
* idtcpu.h: Commented out definition of "wait". It was stupid to
use such a common word as a macro.
* rtems/score/cpu.h (_CPU_ISR_Disable): Fixed for mips ISA 3.
* rtems/score/mips.h: Added include of <idtcpu.h>.
* rtems/score/mips.h (mips_enable_in_interrupt_mask): Corrected.
* custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg: Remove
unneeded definitions when compiled for "mips" rather than "mips64orion."
Correct CPU_CFLAGS.
* src/rtemsInterrupt.cc: Allocated interrupt_table since since
cannot be determined without CPU model information.
* Added r46xx directory.
* Makefile.am, configure.in: Modified to reflect addition of r46xx.
* shared/interrupts/installisrentries.c: Fixed typo.
* r46xx/.cvsignore, r46xx/Makefile.am,
r46xx/vectorisrs/.cvsignore, r46xx/vectorisrs/Makefile.am,
r46xx/vectorisrs/vectorisrs.c: New files.
* Makefile.am: Remove subshell from *.a processing in librtemsall.a
rule.
* scitab/Makefile.am, startup/bspstart.c, configure.in: Removed
rest of make-target-options and moved them to BSP configure options.
* custom/gensh1.cfg: Removed rest of make-target-options and
* include/bsp.h: Changed <sh/null.h> to <rtems/devnull.h> to reflect
the movement of this component to libmisc.
* wrapup/Makefile.am: /dev/null driver is no longer in libcpu/sh.
would be visible.
* /dev/null moved to libmisc.
* Makefile.am, configure.in: Removed null directory.
* include/Makefile.am: Removed null.h.
* include/null.h, null/.cvsignore, null/Makefile.am, null/close.c,
null/cntrl.c, null/init.c, null/open.c, null/read.c, null/write.c:
Removed.
* devnull: New addition. Moved from libcpu/sh.
* devnull/devnull.c, devnull/devnull.h, devnull/.cvsignore,
devnull/Makefile.am: New files.
* Makefile.am, configure.in, wrapup/Makefile.am: Modified to reflect
addition of above.
* bootloader/Makefile.am: Modified to install bootloader so
make-exe rule can avoid writing to install point or assuming
BSP build tree is available.
* automake/compile.am: Add LD.
* custom/mcp750.cfg (make-exe): Rewrite to avoid writing to
install point or assuming BSP build tree is available.
* custom/psim.cfg: Removed unused variables.
* clockdrv_shell.c: Fixed syntax error in fast idle support.
* clock/clock.c: Use shared clock driver shell.
* console/console.c: Removed. Now use shared polling shell.
* console/console-io.c: New file.
* console/Makefile.am: Correct to use shared polling shell.
* startup/bspstart.c: Remove all fast idle references.
* console/console-io.c: Removed unused variable initialized.
* console/console-io.c: Added console_initialize_hardware().
* setup.def, binutils/HISTORY, gccnewlib/HISTORY: Updated
binutils HISTORY to reflect new revision. Updated gcc to fix
i960 C++ problem. Updated newlib to move to newlib 1.9.0.
* custom/sim68000.cfg: Corrected CPU model for simcpu32 configuration.
* custom/simcpu32.cfg: Removed MVME162 reference.
* new_exception_processing/cpu.h, old_exception_processing/cpu.c:
old_exception_processing/cpu.h, Added _CPU_Initialize_vectors().
In particular, spurious vector initialization had to be moved
on old exception processing model.
* clockdrv_shell.c: Added fast idle mode which is enabled by defining
CLOCK_DRIVER_USE_FAST_IDLE.
* console-polled.c: Added console_initialize_hardware() hook.
* ChangeLog: Removed bad entry.
* clock/Makefile.am: Fixed reference to ckinit.c.
* clock/clockdrv.c: Enabled fast idle.
* start/start.S: Added space for vectors on CPU32 configuration.
* startup/bspstart.c: Fixed typo.
* clock: New directory with stub clock driver.
* clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c: New files.
to reflect above.
* cpu_asm.S: Modify to properly dereference _ISR_Vector_table
now that it is dynamically allocated.
* cpu_asm.S: Eliminated warning for duplicate definition of EXTERN.
* ChangeLog: Removed duplicate entry.
* CHANGELOG: Removed.
* README: Merged CHANGELOG contents as initial changes.
* startup/linkcmds: Set _VBR to 0 to indicate that the vectors are
in RAM not ROM. Thanks to Juan Zamorano <jzamora@fi.upm.es> for
debugging this.
* tx39/vectorisrs/vectorisrs.c: Modified to have default exception
vector handler. This should be in a separate file so the BSP can
easily override it.
* timer/timer.c: Removed incorrect comments about ERC32.
