* | new file | Joel Sherrill | 1996-05-28 | 2 | -0/+144 |
* | commented out interrupt support | Joel Sherrill | 1996-05-28 | 3 | -0/+6 |
* | added ifndef's for the POSIX maximum field in the POSIX api configuration table | Joel Sherrill | 1996-05-28 | 3 | -3/+18 |
* | added posix api initialization call to init.c | Joel Sherrill | 1996-05-28 | 4 | -2/+10 |
| | | | | deleted a blank line in rtemsapi.c | ||||
* | comment cleanup | Joel Sherrill | 1996-05-28 | 4 | -8/+4 |
* | added maximum keys | Joel Sherrill | 1996-05-28 | 3 | -0/+3 |
* | made posix configuration information conditional so configurations wanting | Joel Sherrill | 1996-05-28 | 6 | -3/+147 |
| | | | | only the rtems api don't have to include it. | ||||
* | fixed typo | Joel Sherrill | 1996-05-28 | 1 | -1/+1 |
* | changed call to _ISR_Enable() to _ISR_Set_level() in _Thread_Handler. | Joel Sherrill | 1996-05-28 | 2 | -2/+2 |
| | | | | | _ISR_Enable() takes the magic cookie expected by the cpu's status register instead of a simple isr level. | ||||
* | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 44 | -162/+489 |
* | new file | Joel Sherrill | 1996-05-24 | 28 | -0/+674 |
* | changed version to 3.5.17 | Joel Sherrill | 1996-05-24 | 2 | -2/+2 |
* | added Motorola MVME147 BSP submitted by Dominique le Campion | Joel Sherrill | 1996-05-24 | 11 | -0/+1427 |
| | | | | | (Dominique.LECAMPION@enst-bretagne.fr), for Telecom Bretagne and T.N.I. (Brest, France) | ||||
* | changed joel's email address | Joel Sherrill | 1996-05-24 | 1 | -4/+4 |
* | added acknowledgement for Motorola MVME147 from Dominique le Campion | Joel Sherrill | 1996-05-24 | 1 | -0/+4 |
* | new file | Joel Sherrill | 1996-05-24 | 2 | -0/+100 |
* | updates from Tony Bennett to correct calling sequences. | Joel Sherrill | 1996-05-24 | 4 | -0/+4 |
* | new files | Joel Sherrill | 1996-05-24 | 6 | -8/+222 |
* | updates to fix typos | Joel Sherrill | 1996-05-24 | 4 | -48/+42 |
* | new file | Mark Johannes | 1996-05-24 | 2 | -0/+44 |
* | added use of sporadic server scheduling parameters | Joel Sherrill | 1996-05-24 | 14 | -0/+116 |
* | new files | Joel Sherrill | 1996-05-24 | 6 | -0/+192 |
* | clean up on DELAYTIMER_MAX | Joel Sherrill | 1996-05-23 | 6 | -24/+0 |
* | new files | Joel Sherrill | 1996-05-23 | 12 | -0/+408 |
* | unused variable | Joel Sherrill | 1996-05-23 | 2 | -2/+0 |
* | new files | Joel Sherrill | 1996-05-23 | 16 | -0/+416 |
* | new files | Joel Sherrill | 1996-05-23 | 14 | -0/+368 |
* | new files | Joel Sherrill | 1996-05-23 | 6 | -0/+150 |
* | new files | Joel Sherrill | 1996-05-23 | 10 | -0/+288 |
* | new files | Joel Sherrill | 1996-05-23 | 8 | -0/+220 |
* | cleanup | Joel Sherrill | 1996-05-23 | 16 | -24/+24 |
* | new files | Joel Sherrill | 1996-05-23 | 16 | -0/+508 |
* | cleanup status vs. result | Joel Sherrill | 1996-05-23 | 58 | -96/+96 |
* | new files | Joel Sherrill | 1996-05-23 | 10 | -0/+304 |
* | new files | Joel Sherrill | 1996-05-23 | 8 | -0/+268 |
* | new files | Joel Sherrill | 1996-05-23 | 4 | -0/+120 |
* | new files | Joel Sherrill | 1996-05-23 | 12 | -0/+400 |
* | new files | Joel Sherrill | 1996-05-23 | 18 | -0/+576 |
* | updated to reflect more constants and feature macros | Joel Sherrill | 1996-05-23 | 68 | -10/+320 |
* | updates from Tony Bennett | Joel Sherrill | 1996-05-23 | 17 | -106/+161 |
* | added code to insure that delay is always non-zero | Joel Sherrill | 1996-05-23 | 2 | -0/+4 |
* | updates from tony bennett | Joel Sherrill | 1996-05-23 | 1 | -2/+2 |
* | added as example of how to do a bsp which is not in this tree. | Joel Sherrill | 1996-05-23 | 2 | -0/+19 |
* | *** empty log message *** | Joel Sherrill | 1996-05-23 | 2 | -4/+4 |
* | invoke thread stack free routine instead of Workspace free. | Joel Sherrill | 1996-05-23 | 2 | -4/+52 |
* | updates from Tony Bennett. | Joel Sherrill | 1996-05-23 | 3 | -118/+154 |
| | | | | | Broke the setjmp/longjmp pair in the context switch into a separate routine so no code depended on local variables surviving the jump. | ||||
* | created posix test suite with test of header files | Joel Sherrill | 1996-05-22 | 102 | -0/+2758 |
* | Modified to correct variables which defined the range of object classes | Joel Sherrill | 1996-05-22 | 3 | -3/+3 |
| | | | | which are tasks. | ||||
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 31 | -14/+52 |
| | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. | ||||
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 7 | -23/+59 |
| | | | | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. The removed files were moved to newlib as they were duplicates of files already included there. |
