* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 4 | -7/+13 |
| | | | | | * irq/irq.c, irq/irq_asm.S, startup/bspstart.c: Fixed typos and removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -1/+5 |
| | | | | * sh7045/score/cpu_asm.c: Fixed typo. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 5 | -24/+40 |
| | | | | * ChangeLog: Corrected. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -12/+16 |
| | | | | * delay/delay.c, score/ispsh7032.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -2/+6 |
| | | | | * idtcpu.h: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -2/+5 |
| | | | | * cpu.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -109/+113 |
| | | | | * score/cpu_asm.c, score/ispsh7750.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -99/+103 |
| | | | | * score/cpu_asm.c, score/ispsh7045.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 5 | -0/+16 |
| | | | | | | * mpc8xx/console-generic/console-generic.c, mpc8xx/cpm/dpram.c, mpc8xx/exceptions/raw_exception.c, ppc403/clock/clock.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -0/+7 |
| | | | | | * shared/interrupts/installisrentries.c, shared/interrupts/vectorexceptions.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -0/+5 |
| | | | | * gnatcommon.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -1/+11 |
| | | | | * gnatsupp/gnatsupp.c, startup/spurious.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -5/+8 |
| | | | | * clock/ckinit.c, console/console.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -2/+8 |
| | | | | * gdbsci/gdbsci.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -3/+5 |
| | | | | * start/start.S, startup/hw_init.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 4 | -0/+28 |
| | | | | | | * cpu.c: Currently only the mpc8260 BSP supports interrupt nesting. NOTE: These needs to be generalized as the patch is applied to other BSPs. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 4 | -12/+19 |
| | | | | | * clock/p_clock.c, console/console.c, startup/bspstart.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 6 | -12/+20 |
| | | | | | * canbus/canbus.c, clock/p_clock.c, console/console.c, network/network.c, startup/bspstart.c: Removed warnings. | ||||
| | | | | * startup/genpvec.c, tod/todcfg.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -5/+10 |
| | | | | * mips-stub.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -2/+8 |
| | | | | * startup/bspclean.c, startup/bspstart.c: Removed warnings. | ||||
| | | | | * startup/gdb-support.c, startup/linkcmds: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -3/+6 |
| | | | | * console/conscfg.c, startup/bspstart.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -199/+203 |
| | | | | * startup/m68k-stub.c: Removed warnings. | ||||
| | | | | * network/network.c, startup/bspclean.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -10/+15 |
| | | | | * startup/page_table.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 4 | -2/+15 |
| | | | | * startup/bspstart.c: Removed warnings. | ||||
* | *** empty log message *** | Eric Norum | 2002-11-01 | 2 | -10/+15 |
* | Till Straumann's patch to: | Eric Norum | 2002-11-01 | 2 | -0/+26 |
| | | | | | use bootp option 129 to get command line string change inet_ntoa->inet_ntop | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 4 | -2/+10 |
| | | | | * stackchk/check.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -5/+9 |
| | | | | * m68k-stub.c: Corrected typos. | ||||
* | 2002-11-01 Andy Dachs <a.dachs@sstl.co.uk> | Joel Sherrill | 2002-11-01 | 4 | -377/+484 |
| | | | | | * irq/irq.c, irq/irq_asm.S, irq/irq_init.c: Per PR288, add support for _ISR_Nest_level. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 2 | -1/+5 |
| | | | | * rtems/score/cpu.h: Removed warning. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 2 | -2/+7 |
| | | | | | * comm/i386-stub.c: Fixed places where debug_error() was not called with enough arguments. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 2 | -3/+8 |
| | | | | * comm/i386-stub.c: Removed warnings. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 2 | -28/+4 |
| | | | | * src/i386/any/remdeb_xdr.c: Removed warnings. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 2 | -0/+5 |
| | | | | * src/rpc/svc_run.c: Remove warning. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 3 | -1/+9 |
| | | | | | | * src/mallocfreespace.c: Corrected sense of status check to match change inside RTEMS. * src/newlibc.c: Removed warning. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 4 | -2/+10 |
| | | | | * base_mp/apptask.c: Removed warning. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 6 | -62/+10 |
| | | | | | | * src/rdbg.c, src/servtsp.c, src/m68k/rdbg_f.c, src/m68k/any/remdeb_xdr.c, src/powerpc/new_exception_processing/remdeb_xdr.c: Removed warnings. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 5 | -2/+9 |
| | | | | | * rtems_webserver/socket.c, rtems_webserver/uemf.h: Removed warnings. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 4 | -4/+14 |
| | | | | * stackchk/check.c: Removed warning. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 2 | -0/+7 |
| | | | | * network/dec21140.c: Removed warnings. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 4 | -0/+12 |
| | | | | | * mpc6xx/clock/c_clock.c, mpc6xx/exceptions/raw_exception.c, mpc6xx/mmu/bat.c: Removed warnings. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 8 | -4/+21 |
| | | | | | | * bootloader/em86.c, console/inch.c, console/polled_io.c, irq/irq.c, motorola/motorola.c, pci/detect_raven_bridge.c, vectors/vectors_init.c: Removed warnings. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 2 | -1/+6 |
| | | | | * src/regiongetinfo.c: Corrected return value check. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 4 | -2/+7 |
| | | | | * libc/rcmd.c, netinet/in_cksum_arm.c: Removed warnings. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 3 | -2/+9 |
| | | | | | * src/heapgetinfo.c: Fixed comment. * src/mpci.c: Removed warning. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 2 | -1/+9 |
| | | | | * rtems/new-exceptions/cpu.h: Removed warnings. |
